Software Archive
Read-only legacy content
17060 Discussions
Comp-CL: Invalid (inconsistent) license key
Doris_P_
Dear support,
I downloaded the PS 2016 full offline installer for linux yesterday and completed the installation without problem. I then save the license file, EVAL_L__CPP_VLNH-DNKJ67LK.lic, which I received via the email, and set
setenv INTEL_LICENSE_FILE /NFS/home/home3/cpan3/Licenses/EVAL_L__CPP_xxxxx.lic
But when i type "icc -v", the license file does not work. The error is below; I also attached the full output after setting INTEL_LMD_DEBUG=1.
Error: A license for Comp-CL is not available (-8,130).
Comp-CL: Invalid (inconsistent) license key.
 The license key and data for the feature do not match.
 This usually happens when a license file has been altered
I tried various times, reinstalling, requesting license file a couple of more times..., but to no avail. Is the license file you sent me a corrupted one? I attached the license file as well.
It is very frustrating. Please help!
Doris Pan
[email protected]
Corey_A_Intel
License File has been sent to your email.
If you install the product online using the Serial Number you will not need to manually install your new license. Use this option only if you are installing offline.
Place the license file "*.lic" in the following directory, making sure not to change the license file name:
  • On Linux*: /opt/intel/licenses
Cristobal_C_
Hi, I just installed parallel_studio_xe_2016_update1 but when compiling my project I receive
Error: A license for Comp-CL is not available (-76,61026,2).
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /home/intel/licenses
**  3.  /home/castro/intel/compilers_and_libraries_2016.1.150/linux/bin/intel64/../../Licenses
**  4.  /home/castro/Licenses
**  5.  /opt/intel/licenses
**  6.  /Users/Shared/Library/Application Support/Intel/Licenses
**  7.  /home/castro/intel/compilers_and_libraries_2016.1.150/linux/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icc: error #10052: could not checkout FLEXlm license
Could you help me?
Sandeep_D_
do the following to fix this:
source <install dir>/bin/compilervars.sh intel64 (or ia32)
This is mentioned in  https://software.intel.com/en-us/node/522356
Xavier_B_1
I do have the same issue as Cristobald. The fix works but remains temporary (i.e. works during the current session but needs to be re-done at the beginning of each new session).
Do you have a solution to work around this?
Xavier
Devorah_H_Intel
Xavier
Please provide the SN of the license via "Send Author a message" link.
Thank you,
