Software Archive
Read-only legacy content
17060 Discussions
Compile error on the offload mode.
White_B_
Hi~ all,
I met some problems when I transform my codes from non-offload mode to offload mode.
The command I used to compile the codes is: icc -std=c++0x
-openmp -O3 -vec-report=3
The compiler I used is icc. I included <omp.h> in multiple header files. If I don't use the offload mode, the program works well. When I add some "#pragma offload target(mic)" directives, the compiler reports error: function "dtime" called in offload region must have been declared with compatible "target" attribute.
Then I tried adding __attribute__((target(mic))) in the header file between the return type and function name. This time, the compiler reports: error: expected a ")" and warning: declaration does not declare anything
How to deal with this problem?
Thanks!
Four files in total:
Main.h
#ifndef MAIN_H
#define MAIN_H
#include "A.h"
#include <omp.h>
#include <sys/time.h>
using namespace std;
static double __attribute__(((target(mic))) dtime()
//static double dtime()
	double tseconds = 0;
	struct timeval mytime;
	gettimeofday(&mytime,(struct timezone*)0);
	tseconds = (double)(mytime.tv_sec+(double)mytime.tv_usec*1e-6);
	return tseconds;
#endif
Main.cpp
#include "main.h"
int main()
	cout << "Start.\n";
	string my_str = "content_string";
	int N_total = 10, index_counter = 0, numthreads = 0;
	double t_begin = dtime(), t_end;
#pragma offload target (mic)
#pragma omp parallel
#pragma omp master
	numthreads = omp_get_num_threads();
	printf("Initializing.. %d Threads",numthreads);
#pragma omp  parallel for private (index_counter)
	for (index_counter=0; index_counter<N_total; index_counter++)
		if (index_counter==0)
			printf("\n%d threads.\n", numthreads);
		vector< vector<int> > my_vec_vec;
		vector<int> my_vec;
		set<int> my_set;
		unordered_map<int,int> my_u_map;
		int my_int = 1;
		double t_i_start=dtime(), t_i_end;
		A_func_1(my_str,my_vec_vec,my_set,my_u_map);
		t_i_end = dtime();
		A_func_2(my_vec_vec,my_u_map,my_int);
	return 0;
A.h
#ifndef A_H
#define A_H
#include <omp.h>
#include <iostream>
#include <map>
#include <set>
#include <stdlib.h>
#include <string>
#include <time.h>
#include <unordered_map>
#include <vector>
void __attribute__(((target(mic))) A_func_1(string my_str, vector<vector<int> >& my_vec_vec, set<int>& my_set, unordered_map<int,int>& my_u_map);
void __attribute__(((target(mic))) A_func_2(vector<vector<int> >& my_vec_vec, unordered_map<int,int>& my_u_map, int my_int=0);
//void A_func_1(string my_str, vector<vector<int> >& my_vec_vec, set<int>& my_set, unordered_map<int,int>& my_u_map);
//void A_func_2(vector<vector<int> >& my_vec_vec, unordered_map<int,int>& my_u_map, int my_int=0);
#endif
A.cpp
#include "A.h"
	srand(time(NULL));
	int n_length = rand()%10+1;
	for (int i=0; i<n_length ;i++)
		vector<int> temp_vec;
		int m_length = rand()%10+1;
		for (int j=0; j<m_length; j++)
			temp_vec.push_back(rand()%20);
		my_vec_vec.push_back(temp_vec);
void A_func_2(vector<vector<int> >& my_vec_vec, unordered_map<int,int>& my_u_map, int my_int)
	int n = my_vec_vec.size();
	for (int i=0; i<n; i++)
		for (int j=0; j<my_vec_vec.size(); j++)
			my_vec_vec = j;
White_B_
The original problem is settled. It's because the "(" is not match.
Thanks all!
TaylorIoTKidd
Thanks for letting us know.
Taylor
