Software Archive
Read-only legacy content
17060 Discussions
Compiler - - Something weird
WSinc
In this subroutine, the compiler gives me error messages on the first two calls to KOPY.
It tells me that it has "already been used as an external." The next two calls are not flagged. Also, other routines use KOPY and are not flagged.
Why does it not treat the first two references as references to an external?
	integer*1 function comp(a,b)
! compares two numbers
! if a number is longer, the extra places must be zero for equality
	integer*4 aa(0:255),bb(0:255)
	integer*1 swap
	external kopy
	na=a(0)
	nb=b(0)
	if(na.gt.nb)then
	swap=1
	else if (na.lt.nb)then
	swap=-1
	else
	swap=0
	endif
	print *,'swap=',swap
	if(swap.ge.0)then
		call kopy(a,aa) ! this if flagged
		call kopy(b,bb) ! and so is this one
	else
		call kopy(a,bb) !NOT flagged
		call kopy(b,aa) !NOT flagged
	endif
! longer number is always in aa
	minab=min(na,nb)
	comp=0
	do i=1,minab
		if(aa(i).gt.bb(i))then
			comp=1
			exit
		else if(aa(i).lt.bb(i))then
			comp=-1
			exit
		endif
	end do
	print *,'comp=',comp
! if unequal length, see if any extra places are zero
! if any are not zero, aa is greater
	if(comp.eq.0 .and. swap.ne.0)then
		do i=minab+1,na
		if(aa(i).ne.0)comp=1
		end do
	end if
! finally, change result if they were swapped
	if(swap.lt.0)comp=-comp
	return
	end
WSinc
Your Web site removed the CRs and tabs, unfortunately.
Anyway, when I trim down the code, I dsicovered that I had forgotten to type the input aguments. But I still don't see why I got the misleading error message.
I fixed the editing.
The error message highlights A and B as the problem symbols, not KOPY. You have references to a(0) and b(0) earlier, and since these are not declared as arrays, the compiler assumes they are external functions. But if you want to pass an external procedure as an actual argument, an explicit interface or EXTERNAL is required. I agree that the message could be better.
Adding the missing declarations of A and B fixed it.
Steve
