Software Archive
Read-only legacy content
17060 Discussions
Compiling Torque4 with intel-mic support
Rafal_O_
I have a problem with compiling torque with intel-mic support. I get this error :
checking whether to compile with MIC support... yes
checking source/COIPipeline_source.h usability... no
checking source/COIPipeline_source.h presence... no
checking for source/COIPipeline_source.h... no
configure: error: MIC COI LLAPI headers not found
What packages I need to compile it correctly?
In thread: https://software.intel.com/en-us/forums/topic/278102#comment-1720943
there is information that package intel-mic-llapi is needed. Is this true?
Frances_R_Intel
I don't know what, if any, additional packages need to be installed to compile Torque with intel-mic support. I do, however, know that the file COIPipeline_source.h should be there even if all you did was the basic MPSS install. The location of that file changed with the MPSS 3.x releases. The file was previously in /opt/intel/mic/coi/include/source/COIPipeline_source.h. It is now in /usr/include/intel-coi/source/COIPipeline_source.h. Could it be the configure script is looking in the wrong place for the version of the MPSS that you have installed?
james_B_8
I had this problem too. The new mpss versions (post Yocto) changed the locations of everything. The torque configure script still uses the old file locations. You need to find the --with-mic-path option in the configure script and change the default MICLIBS and MICCFLAGS variables to:
MICLIBS="-L/usr/lib64"; MICCFLAGS="-I/usr/include/intel-coi"
That should get it past configuration.
James
