Software Archive
Read-only legacy content
17060 Discussions
Compiling with CUDA Build Rule
_heinz
I installed latest updates from Parallel Studio(update2) 25.03.2011
Intel C++ Compiler for applications running on IA-32, version 12.0.0 Package ID: composer_2011.063
If I compile a CUDA project I get the old rules file error.
3>Compiling with CUDA Build Rule... (Microsoft VC++ Environment)
3>"E:\\CUDA\\v4.0\\\\bin\\nvcc.exe" -G0 -gencode=arch=compute_10,code=\\"sm_10,compute_10\\" -gencode=arch=compute_20,code=\\"sm_20,compute_20\\" --machine 32 -ccbin "C:\\Program Files\\Microsoft Visual Studio 9.0\\VC\\bin" -D_NEXUS_DEBUG -g -Xcompiler "/EHsc /W3 /nologo /O2 /Zi /MT " -I"E:\\CUDA\\v4.0\\/include" -I"./" -I"../../common/inc" -I"../../../shared/inc" -I"E:\\CUDA\\v4.0\\\\include" -maxrregcount=[Value] --compile -o "Release/cppIntegration.cu.obj" cppIntegration.cu
3>nvcc fatal : '[Value]': expected a number
This error is known since december 2010. I'm wondering why the patch is not included in Parallel Studio.
@INTEL can you please proof if the patch is included in Package ID: composer_2011.063
heinz
Mark_S_Intel1
Hi Heinz,
I will look into this issue and get back to you.
--mark
Mark_S_Intel1
Hi Heinz,
The fix for the rules-file error was checked into the database on December 12, 2010. The C++ composer version 2011 (update 3) Build Date March 09, 2011, posted on March 24 2011,(w_ccompxe_ia32_2011.3.175.exe, or w_ccompxe_intel64_2011.3.175.exe)should have the fix.
https://registrationcenter.intel.com/RegCenter/Download.aspx?productid=1411
--mark
