Software Archive
Read-only legacy content
17060 Discussions
Components Not Show- XDK 2893
Ydb
Hello there.
After doing the update (installed in 2893) components, pages, I do not see the panel.
Repeatedly "XDK" I founded remove it again. The problem did not improve.
Can you help?
Rakshith_K_Intel
Can you try making the XDK window size smaller ?
Ydb
The same results.
Ydb
The problem is still not resolved.
John_H_Intel2
Is this with all projects or just this one?
Can you create a new one and see if it returns?
If it does return, can you zip your entire project and post it for us to investigate?
Ydb
the same for all projects.
I just XDK remove and re-established.
But the result is the same.
In addition there is an empty project.
John_H_Intel2
When I imported your app, something odd happened, not the issue you are facing though. Not sure, maybe the forums corrupted the zip. I created a blank AD app and zipped it up. Try downloading,extracting this zip and then importing it to the XDK and let me know how you make out.
https://www.dropbox.com/s/o0dbbvteuvcb6eo/BlankAD-2-17.zip?dl=0
