Criei um aplicativo no JAVA: Onde encontrar auxílio, o qual está disponível na play store.
Agora, criei ele totalmente no INTEL XDK e preciso publicar uma atualização do que já existe lá na play store.
Quando vou fazer a atualização na play store dá um erro por causa da keystore no arquivo .jks
Eu tenho o arquivo necessário, só não sei como resolver esse embaraço todo.
Alguém já passou por isso e pode me ajudar?
- Tags:
- HTML5
- Intel® XDK
INTEL continuity of XDK application created earlier in JAVA
I created an application in JAVA: Where to find help, which is available on the play store.
Now fully he created in INTEL XDK and must publish an update of what is already there in the play store.
When I go to upgrade the play store gives an error because the keystore file in .jks
I have the required file, just do not know how to resolve this every weight.
Has anyone experienced this and can help me?
You must have the original keystore file if you want to update the app. The XDK build system currently creates a unique signing certificate, but this can be replaced. We are adding a facility to allow you to do this directly, which will be available in about a month. In the meantime, if you have the original keystore and the password for that keystore, it may be possible to copy it into your XDK account. If you do not have that information there is nothing we can do for you.
If you have that original info, for the original app, please send an email to html5tools@intel.com and point to this issue. It may take a while to fix this. Again, if you do not have all the original credentials there is nothing we can do to resolve the issue.
