Software Archive
Read-only legacy content
17060 Discussions
Cordova CLI Version
madson_g_
I know the change of CLI version is in Build Settings. Do we have to wait next XDK updates to get newest versions? I have to implement phonegap plugin push and the its recent versions require CLI 6.4.0
PaulF_IntelCorp
We will be issuing a new release that allows you to select CLI 6.5.0. However, if you are migrating to Cordova CLI the version of CLI you use is determined by the version of Cordova CLI that you installed on your system. Otherwise, a workaround, until we provide the new version of the XDK, is to open the ZIP, modify the CLI version number in the config.xml file, rezip and submit to PhoneGap Build.
