Software Archive
Read-only legacy content
17060 Discussions
Cordova errors in simulator console
Alessandro_T_
Why am I getting this errors ?
https://www.dropbox.com/s/8i92jdlyuomifhv/Screenshot%202016-08-11%2014.23.45.png?dl=0
Is there a configuration problem in my XDK environment or is this a normal thing ?
Uncaught module cordova-plugin-device.device already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.FileEntry already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.Entry already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.DirectoryEntry already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.DirectoryReader already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.File already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.FileError already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.FileReader already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.Flags already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.FileWriter already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.FileSystem already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.FileUploadOptions already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.FileUploadResult already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.LocalFileSystem already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.Metadata already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.ProgressEvent already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.fileSystems already defined localhost:60622/cordova.js:79
15Uncaught module cordova-plugin-file.requestFileSystem already defined cordova.js:79
15Uncaught module cordova-plugin-file.iosFileSystem already defined cordova.js:79
15Uncaught module cordova-plugin-file.resolveLocalFileSystemURI already defined cordova.js:79
15Uncaught module cordova-plugin-file.fileSystems-roots already defined cordova.js:79
15Uncaught module cordova-plugin-file.fileSystemPaths already defined cordova.js:79
7Uncaught module cordova-plugin-file-opener2.FileOpener2 already defined cordova.js:79
7Uncaught module cordova-plugin-file-transfer.FileTransferError already defined cordova.js:79
7Uncaught module cordova-plugin-splashscreen.SplashScreen already defined cordova.js:79
7Uncaught module cordova-plugin-statusbar.statusbar already defined cordova.js:79
7Uncaught module cordova-plugin-file-transfer.FileTransfer already defined
PaulF_IntelCorp
See known issues in release notes > https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk <
Bava__Arthur
Same here. A lot of errors which i don't have any clue what's going wrong...
PaulF_IntelCorp
Arthur -- please read the release notes. This is a known issue with the Simulate tab, it has no bearing on your app.
