Software Archive
Read-only legacy content
17060 Discussions
Cordova iOS Build failed
Tina_S_
I updated Intel XDK to the newest version and now I have a new problem building Cordova iOS projects.
It just says the "The build failed. An error occurred while building the application. Verify your build assets are correct and try again", nothing else. Even old projects (which I did not change) fail at building.
I tried to generate a new certificate and created new provisioning files, but still the same error message.
What can I do?
Thank you Tina
David_G_5
Hi Tina,
I have the same problem. Did you manage to solve the issue?
David
Tina_S_
Hello David,
since today its working fine. I think this was an XDK problem, which they solved. I did not change anything!
Kind regards
Tina
David_G_5
Thanks, for your reply.
Anyone know how to escalate this to Intel?
David
Elroy_A_Intel
I will escalate your experienced issue to the engineering team.
michele_f_
i have the same problem.
All yesterday spent to solve the problem.
PaulF_IntelCorp
I'm guessing this is being caused by a third-party plugin. Try removing each plugin one-by-one and then build after each removal, to see if one of your plugins is causing this problem.
