Software Archive
Read-only legacy content
17060 Discussions
Core Temperature at Xeon Phi
Aya
Hello everybody,
I want to purchase Xeon Phi Coprocessor for researching purposes,
and I want to know if I can get each core temperature using its tools and software ??
Thanks in advance,
Heba
TimP
Yes, for example by the micsmc or micsmc-gui tool.
Aya
So, just to be sure, I can get at a speccific time 80 temperature values for the 80 running cores ?
TimP
No temperature measurements by individual cores.  The tool does show CPU utilization by core.
Aya
So micsmc tool just give one temperature value of the whole cores (maybe the maximum or average).
Aya
I have seen some researcher used Intel's Quad-core system with a Machine Specific Register (MSR) to access Digital Thermal Sensor.
In MSR, they use IA32_THERM_STATUS register in order to get temperature of each core.
Is there something similar in Xeon Phi, till we get the temperature for each core ???
Thanks in advance
TaylorIoTKidd
I'm trying to find the answer for you. The first person I contacted said that he knows of none, but this isn't a definite answer.
Aya
Ok. Thanks. I will wait, because my decision of buying it depends on this point.
I found already in the file: xeon-phi-software-developers-guide
Table 2-12 Intel MIC Architecture commands
micsmc: displays the card thermal, electrical and usage parameters. For example:core temperature, core usage,.....
So, does it mean the temperature of each core or one value for the all cores ????
Thanks in advance
TaylorIoTKidd
In micsmc it says "average core temperature," so I assume it's an average across all the cores.
As far as I can tell, it isn't in the list of PMU (Performance Monitoring Unit) events given by http://software.intel.com/sites/default/files/forum/278102/intelr-xeon-phitm-pmu-rev1.01.pdf.
I'm still trying to find out if we can get individual core temperatures. Something calculates the average from some data.
Taylor
Clayton_C_Intel
Unlike other IA cores, there is not a temperature sensor for every core on the first generation Xeon Phi. Instead, there are a series of sensors scattered around the die. They can be accessed by reading the CURRENT_DIE_TEMPn registers in SBOX. The Intel(R) Xeon Phi(TM) Coprocessor Systems Software Developers Guide has the location of these registers in MMIO.
Aya
thank you for this information ..
