Software Archive
Read-only legacy content
17060 Discussions
Correctly profiling MPI application on the MIC (separate results for each process)
Alastair_M_
Dear all,
Following the instructions here https://software.intel.com/en-us/forums/topic/358774 I have been able to profile my MPI application on the MIC, however the results are not collected exactly how I would expect.
I am not seeing a separate results directory for each MPI process, rather a single result set for the whole application.
I am using the following command line with Vtune 2013 Update 15:
/opt/intel/vtune_amplifier_xe_2013/bin64/amplxe-cl -collect knc-hotspots -r res -knob enable-user-tasks=true -app-working-dir /usr/bin -source-search-dir=/home/alastair/mpi_testing/src -search-dir=/home/alastair/mpi_testing/src -- ssh mic0 mpirun -n 128 -wdir /mic0fs/ /home/alastair/mpi_testing
What am I actually seeing in the results?  Is this an aggregation of profiles for all MPI processes?
What is required to see the results of each process individually?
Alastair
TimP
As Peter indicated in that reference you have aggregated results of all ranks and threads. Filtering by cores would select individual ranks. Assuming you pin each rank to a group of cores as is normal.
TimP
Alastair_M_
Hi Tim,
Thanks for your reply.  I didn't realise that I could filter from this to point to individual MPI ranks.  I was expecting to see the result for each rank in a separate directory, as indicated in the reference.
I see now that I can filter by thread inside Vtune.
Thanks for your help Tim.
Alastair
