Software Archive
Read-only legacy content
17060 Discussions
Could not generate debug module
klevis
I am trying to use the following third party plugin https://github.com/kalpeshhpatel/cordova-tapjoy-plugin to integrate with Tapjoy.
But, when trying to do a debug on my android phone i get the following error.
  • The App ID is "com.intel.appx.Test.xwalk15"
  • The App Name is "AP Debug x15 Test"
  • Application will be signed.
  • Plugin "cordova-plugin-statusbar" (1.0.0) installed.
  • Plugin "cordova-plugin-device" (1.0.1) installed.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Error: Plugin "org.apache.cordova.plugin.TapjoyPlugin" (1.0) failed to install.
  • Plugin "com.intel.xdk.ppfa" (1.0) installed.
The plugin fails to install. Has anyone else experienced this issue? Can this  be an issue with the plugin itself?.
I am using Crosswalk version 15, Intel XDK 2611, Cordova CLI 5.1.1
Any help is appreciated.
PaulF_IntelCorp
This is likely an issue with the plugin. Are you able to build your app with that plugin? Try performing a Crosswalk build (the debug builds are Crosswalk builds) using CLI 4.1.2 and Crosswalk 14, this will be the closest simulation of a debug build. From that you should be able to get a detailed build log which might shed some light on the problem.
PaulF_IntelCorp
klevis
Thanks for the reply. I tried downgrading the project to CLI 4.1.2 and Crosswalk 14 and it worked. I guess the plugin is not yet compatible with the new CLI version and Crosswalk.
