I update the mic flash, but it failed.
Any help will be appreciated.
[root@supermicro mpss_gold_update_3]# /opt/intel/mic/bin/micflash -update /opt/intel/mic/flash/EXT_HP2_SMC_Bootloader_1_8_4326.css_ab -device 0 -noreboot
mic0: Flash image: /opt/intel/mic/flash/EXT_HP2_SMC_Bootloader_1_8_4326.css_ab
mic0: SMC update started
micflash: mic0: Flash operation timed out
mic0: Resetting
The following is micinfo:
[root@supermicro mpss_gold_update_3]# /opt/intel/mic/bin/micinfo
MicInfo Utility Log
Created Mon Aug 19 16:04:31 2013
System Info
HOST OS : Linux
OS Version : 2.6.32-358.el6.x86_64
Driver Version : 6720-16
MPSS Version : 2.1.6720-16
Host Physical Memory : 65945 MB
Device No: 0, Device Name: mic0
Version
Flash Version : NotAvailable
SMC Firmware Version : NotAvailable
SMC Boot Loader Version : NotAvailable
uOS Version : NotAvailable
Device Serial Number : NotAvailable
Board
Vendor ID : 0x8086
Device ID : 0x2250
Subsystem ID : 0x2500
Coprocessor Stepping ID : 3
PCIe Width : x16
PCIe Speed : 5 GT/s
PCIe Max payload size : 256 bytes
PCIe Max read req size : 512 bytes
Coprocessor Model : 0x01
Coprocessor Model Ext : 0x00
Coprocessor Type : 0x00
Coprocessor Family : 0x0b
Coprocessor Family Ext : 0x00
Coprocessor Stepping : B1
Board SKU : NotAvailable
ECC Mode : NotAvailable
SMC HW Revision : NotAvailable
Cores
Total No of Active Cores : NotAvailable
Voltage : NotAvailable
Frequency : NotAvailable
Thermal
Fan Speed Control : NotAvailable
Fan RPM : NotAvailable
Fan PWM : NotAvailable
Die Temp : NotAvailable
GDDR
GDDR Vendor : NotAvailable
GDDR Version : NotAvailable
GDDR Density : NotAvailable
GDDR Size : NotAvailable
GDDR Technology : NotAvailable
GDDR Speed : NotAvailable
GDDR Frequency : NotAvailable
GDDR Voltage : NotAvailable
Maybe the result of "miccheck" is also needed? "miccheck" can tell you what the flash version you are currently using.
Try this method http://software.intel.com/en-us/comment/1747898
It has helped me for 3 times to update 3 cards 5110P.
