Software Archive
Read-only legacy content
17060 Discussions
Creative GestureCam Not work with Depth...
Avan_T
I tested with Intel RealSenseSDK
1. Creative GestureCam Not work with depth and something other, it work same normal camera. Have any update for GestureCam work for RealSense?
2. C#, Face Tracking Issue when select device (more then 2 camera), c++ work normal
3. Have any script JavaScript for Hand/Object tracking?
Pubudu-Silva_Intel
Are you using creative camera which came with PerC SDK 2013? If that is the case it won't work with the RealSense SDK (RSSDK). You have to get the  RealSense Camera for RSSDK and you can reserve that at http://click.intel.com/intelr-realsensetm-developer-kit.html.
There are some sample apps (with source code) that demonstrate you how to use RSSDK to code JavaScript apps to do face/hand tracking, gesture recognition etc... and they all come with your RSSDK installation.
Pubudu-Silva_Intel
Avan_T
I tested with creative camera 2013, it won't work but i think it must have some update for creative camera 2013 can work for its because the creative camera 2013 it have support depth.
Thank you PUBUDU S. (Intel)!
daflippers
There is a lot of confusion at the moment.  The situation at this point in time is:
1 The Creative GestureCam is available but is only supported by the Intel Perceptual Computing SDK which is no longer available from Intel.
2 The Intel RealSense 3D camera is not available yet however the Intel RealSense SDK 2014 for Windows Beta is available.
So if you have a GestureCam you need to use the PerC and if you want to use the RealSense SDK there is currently no hardware available to test your work.  Just be aware of this.
David
MartyG
Intel's recent opinion on this subject was that the 2013 Senz3D cam will apparently work with the 2014 SDK with some of its functions such as emotion and speech recognition, object tracking, face tracking and synthesis.  What will not work with the 2013 cam are features that use depth analysis and infra-red feeds, as these are RealSense cam features.
Some people say they have seen release notes stating that the 2014 SDK is totally incompatible with the 2013 cam.  I haven't seen those, so can only speak for the information above that was provided by Intel's representative.
There is indeed a lot of confusion about this topic!
daflippers
Hi Marty,
Agreed.  And of course there is the Haswell requirement for the SDK yet Intel state:
Coming to Intel® Core™ and Intel® Atom™ processor-based tablets running both Microsoft Windows* and Android*, is the advanced technology that makes this possible: the Intel RealSense 3D camera.
If you’re a software developer, look for the following capabilities in a future version of the Intel RealSense software development kit (SDK).
Of course it could be that the SDK requires Haswell for certain applications that will not be supported on Android.
David
MartyG
Yes, it could be that the SDK needs certain technologies that are not needed in the final exported application.  This is quite common with development engines.  It's kinda like how Android applications can be written on a PC in dev environments like Eclipse and Android Studio, but those packages aren't needed for the final compiled application to work on the actual tablet.
SoftKinetic
Dear All,
To continue to use your Creative SenZ3D camera or the SoftKinetic DepthSense 325 feel free to download iisu 3.6 here:
http://www.softkinetic.com/en-us/support/download.aspx
It includes the original hand tracking features plus additional tools and samples.
If you're excited by VR, please check out our www.reachVR.com challenge. You'll find everything you need to use your camera with the Oculus Rift!
Best,
The SoftKinetic team
Majid_N_
SoftKinetic, May I know this SDK can support Depth scanning for face tracking? (or for example can I use this SDK to find the distance between user head and camera by IR sensor?)
Majid
