Software Archive
Read-only legacy content
17060 Discussions
Creative Senz3D
Chee_Wang_L_
I'm purchasing a Creative Senz3D for 3D apps development.  I want to confirm if RealSense SDK is compatible with Creative Senz3D.  Please advise.
Chee-Wang
Tim_T_
It is not compatible.
Chee_Wang_L_
In that case, what SDK should I be using if I have a Senz3D?
Tri
Creative Senz3D camera would work with Intel Perceptual Computing (PerC) SDK
(RealSense was previously known as Perceptual Computing).
Previously you can get Perceptual Computing SDK from
    https://software.intel.com/en-us/perceptual-computing-sdk
but, as you may see, it has been permanently removed now.
Intel recommend developers to upgrade to RealSense SDK and the new RealSense 3D camera,
though that we may still work with Senz3D camera and PerC SDK.
Tri
samontab
Valued Contributor II
If I were you, I would keep a local copy of that installer, or update to the RealSense SDK, as Intel clearly does not want to keep supporting the previous Perceptual Computing SDK.
Tri
Yup, updating to RealSense SDK would be more recommended.
Tri
If you need any further information or discussion regarding PerC SDK you can go to Intel Perceptual Computing SDK forum at
https://software.intel.com/en-us/forums/intel-perceptual-computing-sdk
It seems that the forum is still active too.
samontab
I think that the RealSense Camera is better overall compared to the previous Senz3D, and it will definitely get more updates in the future. Is there any reason for using the previous camera and not the current one?. Just curious...
