Hi
I use Android crosswalk 10 on my Android Kitkat, input file functioning correctly for opening file explorer, however if we decided to go back, this reboot the app (return in spalshscreen). Similarly, if you select a file.
No error in the log of the google console in debug mode. Maybe a java problem, I must tried in emulating the app in eclipse.
The problem is it on the webview (crosswalk 10)? Cordova?
Does anyone has the same behavior?
- Tags:
- HTML5
- Intel® XDK
I believe it is Crosswalk 10 issue. I'll look into it more.
Swati
XDK now has Crosswalk 11 and 12 available. Please try with either and see if it fixes the issue.
note: If you don't see 11 & 12 in the drop down list, please clear the XDK cache.
Swati
