Software Archive
Read-only legacy content
17060 Discussions
Crosswalk build fails with version 17 and 18 (16 OK)
Andrea_C_
Hi to everyone,
we are hit from this bug (so that we are not able to build are app), which was solved in that issue:
https://crosswalk-project.org/jira/browse/XWALK-6116
Do the current build systems have integrated this patch?
Andrea
Andrea_C_
Better explaination:
We obtain this error
:compileArmv7ReleaseJava.../cordova_project/platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java:71: error: onJsAlert(XWalkView,String,String,XWalkJavascriptResult) in XWalkCordovaUiClient cannot override onJsAlert(XWalkView,String,String,XWalkJavascriptResult) in XWalkUIClient
    private boolean onJsAlert(XWalkView view, String url, String message,
  attempting to assign weaker access privileges; was public
.../cordova_project/platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java:89: error: onJsConfirm(XWalkView,String,String,XWalkJavascriptResult) in XWalkCordovaUiClient cannot override onJsConfirm(XWalkView,String,String,XWalkJavascriptResult) in XWalkUIClient
    private boolean onJsConfirm(XWalkView view, String url, String message,
.../cordova_project/platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java:112: error: onJsPrompt(XWalkView,String,String,String,XWalkJavascriptResult) in XWalkCordovaUiClient cannot override onJsPrompt(XWalkView,String,String,String,XWalkJavascriptResult) in XWalkUIClient
    private boolean onJsPrompt(XWalkView view, String origin, String message, String defaultValue,
when the inappbrowser plugin is included, which overrides these methods. Crosswalk webview had this method private until the patch was applied.
PaulF_IntelCorp
Andrea -- you can try using CW19 (and later) using this technique in the additions file:
<!-- Set the Crosswalk embedded library to something other than those listed in the UI -->
<!-- https://github.com/crosswalk-project/crosswalk-website/wiki/Release-dates -->
<!-- https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/ -->
<!-- https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library_beta/ -->
<!-- https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview#configure -->
<!--<preference name="xwalkVersion" value="18+"/>-->
<!--<preference name="xwalkVersion" value="14.43.343.24" />-->
<!--<preference name="xwalkVersion" value="org.xwalk:xwalk_core_library_beta:19+" />-->
Obviously, you'll have to uncomment and change the version number to get what you want. When you do this, it overrides whatever is in the build settings AND will likely not work with the Debug tab builds. So, for example, if you wanted to build with CW19, you could do this:
<preference name="xwalkVersion" value="19+"/>
Andrea_C_
Yes, with the option:
works, so watch out for this error!
Andrea_C_
Sorry Paul, I was building with crosswalk 16 :-(
With crosswalk 20 (latest stable version) I get the same error.
I am quite sure it depends on a outdated plugin  cordova-plugin-crosswalk-webview
This cannot be modified by our side (I think)
Andrea_C_
Figured out:
Crosswalk 17+ needs at least cordova cli 5.4.1.
By upgrading all the problems are solved.
PaulF_IntelCorp
Great news! :-)
