Software Archive
Read-only legacy content
17060 Discussions
Crosswalk build generate estrange app version code
Hamilton_Tenório_da_
Valued Contributor I
In the last croswalk build, the app version code generated are 80010 e 120010 (arm e x86) when the code were 60010.
I just upgrade the XDK Version (1816) and generate a crosswalk build of one application. In build settings the app version code was set as 60011 (the last one was 60010). After try to upload a new APK to google play, it informs that the version is lower then the actual one (60000). The same occurs with the other APK (20000).
Is there a new form to set the app version code in crosswalk?
In short:
Last version XDK app version code in projet: 60010
apk generated: 80010 and 120010
Now app version code in projet: 60011
apk generated: 60000 and 20000
John_H_Intel2
Ok, the issue has been resolved. Please reupload and build your crosswalk app. The correct version should now be set.
John_H_Intel2
Issue replicated. I will post back when the fix is live.
OK. Thanks.
John_H_Intel2
Yes!! Now is OK!
Thank you.
