Software Archive
Read-only legacy content
17060 Discussions
Crosswalk error on android
Shohanur_R_
I have build a very simple game with crosswalk but when I run the game on my android device its showing an error popup like 'The connection to the server was unseccessfu.(file:///android_asset/www/index.html) '.
please tell me how to resolve this.
Shohanur_R_
I have solved my problem. I set a timeout in config.xml file and now its ok.
Amrita_C_Intel
The problem might be solved by adding a timeout to call your index.html
ie you need to add super.setIntegerProperty("loadUrlTimeoutValue", 70000)
Explanation:
This can be happened due to the following reasons
The core reason: the problem is likely due to the speed of the emulator so the network is too slow complete the communication in a timely fashion.
This can be due to:
  1. Your code/data/image is of too much of size
  2. Your script may have a infinite or long loop, so that it takes too much of time to load.
  3. You will be using too much of scripts (jQuery, iscroll, etc etc.. more number of plugins or scripts )
Shohanur_R_
I am using intel xdk to build I did not found any activity.java file inside my project folder.
Amrita_C_Intel
Amrita_C_Intel
And can you post a screenshot of the error message? And can you send your.zip file of your project?
Shohanur_R_
