Software Archive
Read-only legacy content
Crosswalk
Nas_N_
Hi!
When I build my app with Crooswalk for Android everything works just fine, all the page's are loaded, but when I build my app with the normal Android, most of the page's are empty, seems like it won't connect to the database... Can anyone help me?
Barry_Johnson
You haven't given much to go on. If it works with Crosswalk, I'd use Crosswalk. Otherwise, you'll need to figure out what isn't supported on your device (and other devices). What Android OS version is your device?
Nas_N_
I have test it on many Android devices, Android 4.0.3, Android 5.1 etc... The reason why I don't want to use Crosswalk is because of the big APK size. Its almost 23 MB, I don't know if that will be a issue on Google Play Store...
Barry_Johnson
I understand regarding the Crosswalk size. I don't think you will have a problem with it on the Play store however. Can you isolate the problem to the failure of the server access from the app? (i.e. would that cause your pages not to display as well?). If that is the issue, I wonder if it is some sort of issue with XHR and any whitelist you have specified.
Does it work/not work using the on-device debugging?
Nas_N_
On-device debugging works fine, but as soon as I build it and install the APK file some of the page's wont load. But I am ready to go with Crosswalk.. but I need to be careful with the 50MB limit on Google Play Store I think...
