Software Archive
Read-only legacy content
17060 Discussions
Cryptography ( Codebreaking ) - Deciphering messages encrypted with Lorenz SZ40 cipher machine
SergeyKostrov
Valued Contributor II
Cryptography ( Codebreaking ) - Deciphering messages encrypted with Lorenz SZ40 cipher machine The Vernam cipher implemented by the Lorenz SZ40 machines utilizes the Boolean "exclusive or" ( XOR ) function. Note: Tests only
SergeyKostrov
A set of KNL server ( 64 cores ) tests...
SergeyKostrov
 [ Intel C++ compiler build messages on Linux ]
  icpc @./BuildCfg/IccXxx.Bin64.cfg -o GccTestApp64.out
  *** ScaLib Message: Compiling with Intel C++ compiler v17.0.4 ***
  *** ScaLib Message: Configuration - Desktop - _POS64_GCC - RELEASE ***
  *** ScaLib Message: Compiling for Intel Processing Unit ( 64-bit x86_64 ) ***
  *** ScaLib Message: Default IRT-Domain MIC-AVX512 ***
  *** ScaLib Message: Classic Processing Model ***
  *** ScaLib Message: Declaration of IRT-Domains ***
  *** ScaLib Message: Multibyte Character Set ***
  *** ScaLib Message: Support of HRT-Functions Enabled ***
  *** ScaLib Message: Support of IRT-Domains Enabled ***
SergeyKostrov
 [ Number of OpenMP Threads :    8 ]
  Application - GccTestApp - POS64_GCC ( 64-bit ) - Release
  Tests: Start
  > Test1155 Start <
  Sub-Test 01 - Generates KeySet values
   Keys         : 08 16 08 08 04 12 14 08 04 16 02 08 05 16 08 12 04 08 16 16 08 08 14 08
  Sub-Test 02 - Displays KeySet values
   Min Key value: 01
   Max Key value: 16
  Sub-Test 03.1 - Displays PlainSet and CipherSet messages
   Plain  Text: HELLO LORENZ SZXX CIPHER
   Cipher Text: @UDDK,BGVULR%CRT\(SYX@KZ
  Sub-Test 04.3 - Deciphers CipherSet message
  Number of Characters (N) : 27
  Length of Sub-String (L) : 4
  Number of Cases to Verify: 531441 where NofCV = N^L
  Memory Allocated         : 0.002 GB
  Generating DataSet
  Identification
   Cipher: '@UDD' - Crib: 'HELL' - Keys: 08 16 08 08 - Offset:  0
   Cipher: 'K,BG' - Crib: 'O LO' - Keys: 04 12 14 08 - Offset:  4
   Cipher: 'VULR' - Crib: 'RENZ' - Keys: 04 16 02 08 - Offset:  8
   Cipher: '%CRT' - Crib: ' SZX' - Keys: 05 16 08 12 - Offset: 12
   Cipher: '\(SY' - Crib: 'X CI' - Keys: 04 08 16 16 - Offset: 16
   Cipher: 'X@KZ' - Crib: 'PHER' - Keys: 08 08 14 08 - Offset: 20
   Cipher: 'X@KZ' - Crib: 'WINT' - Keys: 15 09 05 14 - Offset: 20
  Deallocates Memory
  Test Completed in 310169 ms
SergeyKostrov
 [ Number of OpenMP Threads :   16 ]
  Tests: Start
  > Test1155 Start <
   Keys         : 12 08 08 16 08 08 08 16 08 08 08 16 12 16 08 04 09 16 14 16 08 16 08 16
   Min Key value: 01
   Max Key value: 16
   Cipher Text: DMD\G(D_ZMFJ,CR\Q0MYXXMB
  Generating DataSet
  Identification
   Cipher: 'DMD\' - Crib: 'HELL' - Keys: 12 08 08 16 - Offset:  0
   Cipher: 'G(D_' - Crib: 'O LO' - Keys: 08 08 08 16 - Offset:  4
   Cipher: 'ZMFJ' - Crib: 'RENZ' - Keys: 08 08 08 16 - Offset:  8
   Cipher: ',CR\' - Crib: ' SZX' - Keys: 12 16 08 04 - Offset: 12
   Cipher: 'Q0MY' - Crib: 'X CI' - Keys: 09 16 14 16 - Offset: 16
   Cipher: 'XXMB' - Crib: 'PHER' - Keys: 08 16 08 16 - Offset: 20
  Deallocates Memory
  Test Completed in 161136 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Number of OpenMP Threads :   32 ]
  Tests: Start
  > Test1155 Start <
   Keys         : 12 16 06 16 08 16 16 16 16 16 16 12 08 12 16 08 05 16 02 16 08 08 14 13
   Min Key value: 01
   Max Key value: 16
   Cipher Text: DUJ\G0\_BU^V(_JP]0AYX@K_
  Generating DataSet
  Identification
   Cipher: 'DUJ\' - Crib: 'HELL' - Keys: 12 16 06 16 - Offset:  0
   Cipher: 'G0\_' - Crib: 'O LO' - Keys: 08 16 16 16 - Offset:  4
   Cipher: 'BU^V' - Crib: 'RENZ' - Keys: 16 16 16 12 - Offset:  8
   Cipher: '(_JP' - Crib: ' SZX' - Keys: 08 12 16 08 - Offset: 12
   Cipher: ']0AY' - Crib: 'X CI' - Keys: 05 16 02 16 - Offset: 16
   Cipher: 'X@K_' - Crib: 'PHER' - Keys: 08 08 14 13 - Offset: 20
   Cipher: 'X@K_' - Crib: 'RENZ' - Keys: 10 05 05 05 - Offset: 20
   Cipher: 'X@K_' - Crib: 'WINT' - Keys: 15 09 05 11 - Offset: 20
  Deallocates Memory
  Test Completed in 80065 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Number of OpenMP Threads :   64 ]
  Tests: Start
  > Test1155 Start <
   Keys         : 16 08 16 16 08 10 08 08 16 05 16 02 04 06 15 16 16 05 08 08 16 16 08 12
   Min Key value: 01
   Max Key value: 16
   Cipher Text: XM\\G*DGB@^X$UUHH%KA@XM^
  Generating DataSet
  Identification
   Cipher: 'XM\\' - Crib: 'HELL' - Keys: 16 08 16 16 - Offset:  0
   Cipher: 'G*DG' - Crib: 'O LO' - Keys: 08 10 08 08 - Offset:  4
   Cipher: 'B@^X' - Crib: 'RENZ' - Keys: 16 05 16 02 - Offset:  8
   Cipher: '$UUH' - Crib: ' SZX' - Keys: 04 06 15 16 - Offset: 12
   Cipher: 'H%KA' - Crib: 'O LO' - Keys: 07 05 07 14 - Offset: 16
   Cipher: 'H%KA' - Crib: 'X CI' - Keys: 16 05 08 08 - Offset: 16
   Cipher: '@XM^' - Crib: 'PHER' - Keys: 16 16 08 12 - Offset: 20
  Deallocates Memory
  Test Completed in 41307 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Number of OpenMP Threads :  128 ]
  Tests: Start
  > Test1155 Start <
   Keys         : 16 08 16 08 12 08 16 08 08 10 16 16 10 16 16 08 16 16 10 16 04 16 08 15
   Min Key value: 01
   Max Key value: 16
   Cipher Text: XM\DC(\GZO^J*CJPH0IYTXM]
  Generating DataSet
  Identification
   Cipher: 'XM\D' - Crib: 'HELL' - Keys: 16 08 16 08 - Offset:  0
   Cipher: 'C(\G' - Crib: 'O LO' - Keys: 12 08 16 08 - Offset:  4
   Cipher: 'ZO^J' - Crib: 'RENZ' - Keys: 08 10 16 16 - Offset:  8
   Cipher: '*CJP' - Crib: ' SZX' - Keys: 10 16 16 08 - Offset: 12
   Cipher: 'H0IY' - Crib: 'X CI' - Keys: 16 16 10 16 - Offset: 16
   Cipher: 'TXM]' - Crib: 'PHER' - Keys: 04 16 08 15 - Offset: 20
  Deallocates Memory
  Test Completed in 42451 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Number of OpenMP Threads :  256 ]
   Keys         : 05 02 16 04 08 08 16 14 16 16 08 04 08 16 16 12 08 03 16 05 04 08 04 04
   Min Key value: 01
   Max Key value: 16
   Cipher Text: MG\HG(\ABUF^(CJTP#SLT@AV
  Generating DataSet
  Identification
   Cipher: 'MG\H' - Crib: 'HELL' - Keys: 05 02 16 04 - Offset:  0
   Cipher: 'G(\A' - Crib: 'O LO' - Keys: 08 08 16 14 - Offset:  4
   Cipher: 'BUF^' - Crib: 'RENZ' - Keys: 16 16 08 04 - Offset:  8
   Cipher: '(CJT' - Crib: ' SZX' - Keys: 08 16 16 12 - Offset: 12
   Cipher: 'P#SL' - Crib: 'X CI' - Keys: 08 03 16 05 - Offset: 16
   Cipher: 'T@AV' - Crib: 'WINT' - Keys: 03 09 15 02 - Offset: 20
   Cipher: 'T@AV' - Crib: 'PHER' - Keys: 04 08 04 04 - Offset: 20
   Cipher: 'T@AV' - Crib: 'RENZ' - Keys: 06 05 15 12 - Offset: 20
  Deallocates Memory
  Test Completed in 43021 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Number of OpenMP Threads :  512 ]
  Tests: Start
  > Test1155 Start <
   Keys         : 12 08 08 16 08 10 16 16 16 08 08 08 08 08 08 16 02 08 16 08 16 16 12 16
   Min Key value: 01
   Max Key value: 16
   Cipher Text: DMD\G*\_BMFR([RHZ(SA@XIB
  Generating DataSet
  Identification
   Cipher: 'G*\_' - Crib: 'O LO' - Keys: 08 10 16 16 - Offset:  4
   Cipher: 'BMFR' - Crib: 'RENZ' - Keys: 16 08 08 08 - Offset:  8
   Cipher: '([RH' - Crib: ' SZX' - Keys: 08 08 08 16 - Offset: 12
   Cipher: 'Z(SA' - Crib: 'X CI' - Keys: 02 08 16 08 - Offset: 16
   Cipher: '@XIB' - Crib: 'PHER' - Keys: 16 16 12 16 - Offset: 20
  Deallocates Memory
  Test Completed in 42787 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Number of OpenMP Threads : 1024 ]
  Tests: Start
  > Test1155 Start <
   Keys         : 08 08 08 12 08 01 16 08 08 14 04 08 16 06 16 16 16 08 08 08 16 04 04 08
   Min Key value: 01
   Max Key value: 16
   Cipher Text: @MD@G!\GZKJR0UJHH(KA@LAZ
  Generating DataSet
  Identification
   Cipher: '@MD@' - Crib: 'HELL' - Keys: 08 08 08 12 - Offset:  0
   Cipher: 'G!\G' - Crib: 'O LO' - Keys: 08 01 16 08 - Offset:  4
   Cipher: 'ZKJR' - Crib: 'RENZ' - Keys: 08 14 04 08 - Offset:  8
   Cipher: 'ZKJR' - Crib: 'WINT' - Keys: 13 02 04 06 - Offset:  8
   Cipher: '0UJH' - Crib: ' SZX' - Keys: 16 06 16 16 - Offset: 12
   Cipher: 'H(KA' - Crib: 'O LO' - Keys: 07 08 07 14 - Offset: 16
   Cipher: 'H(KA' - Crib: 'X CI' - Keys: 16 08 08 08 - Offset: 16
   Cipher: '@LAZ' - Crib: 'PHER' - Keys: 16 04 04 08 - Offset: 20
  Deallocates Memory
  Test Completed in 42839 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Number of OpenMP Threads : 2048 ]
  Tests: Start
  > Test1155 Start <
   Keys         : 16 08 08 04 04 08 08 12 10 08 16 12 16 16 08 08 06 08 08 08 12 08 06 12
   Min Key value: 01
   Max Key value: 16
   Cipher Text: XMDHK(DCXM^V0CRP^(KA\@C^
  Generating DataSet
  Identification
   Cipher: 'XMDH' - Crib: 'HELL' - Keys: 16 08 08 04 - Offset:  0
   Cipher: 'K(DC' - Crib: 'O LO' - Keys: 04 08 08 12 - Offset:  4
   Cipher: 'XM^V' - Crib: 'RENZ' - Keys: 10 08 16 12 - Offset:  8
   Cipher: 'XM^V' - Crib: 'WINT' - Keys: 15 04 16 02 - Offset:  8
   Cipher: '0CRP' - Crib: ' SZX' - Keys: 16 16 08 08 - Offset: 12
   Cipher: '^(KA' - Crib: 'X CI' - Keys: 06 08 08 08 - Offset: 16
   Cipher: '\@C^' - Crib: 'PHER' - Keys: 12 08 06 12 - Offset: 20
   Cipher: '\@C^' - Crib: 'RENZ' - Keys: 14 05 13 04 - Offset: 20
   Cipher: '\@C^' - Crib: 'WINT' - Keys: 11 09 13 10 - Offset: 20
  Deallocates Memory
  Test Completed in 42878 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
For evaluation here are an Ivy Bridge ( IVB ) set of tests since that Intel architecture is widely used on super-computing systems. Take into account that in most cases processing on a KNL server with 16 OpenMP threads is almost the same as processing on an IVB system with 8 OpenMP threads. Shortly speaking in terms of processing speed on these two architectures: 16 threads on KNL ~= 8 threads on IVB
SergeyKostrov
 [ Intel C++ compiler build messages on Windows 7 ]
  Compiling with Intel(R) C++ Compiler XE 13.1.0.149 [Intel(R) 64]... (Intel C++ Environment)
  Stdphf.cpp
  *** ScaLib Message: Compiling with Intel C++ compiler v13.1.2 ***
  *** ScaLib Message: Configuration - Desktop - _NOS64_ICC - RELEASE ***
  *** ScaLib Message: Compiling for Intel Processing Unit ( 64-bit ) ***
  *** ScaLib Message: Compiling for AMD Processing Unit ( 64-bit ) ***
  *** ScaLib Message: Default IRT-Domain AVX ***
  *** ScaLib Message: Unicode Character Set ***
  IccTestApp.cpp
  Linking... (Intel C++ Environment)
  ipo: warning #11072: ignoring invalid linker directive 'NODEFAULTLIB:libcpmt.lib'
  xilink: executing 'link'
  Creating library x64\Release/IccTestApp64.lib and object x64\Release/IccTestApp64.exp
  Embedding manifest... (Microsoft VC++ Environment)
  IccTestApp - 0 error(s), 1 warning(s), 0 remark(s)
SergeyKostrov
 [ Number of OpenMP Threads :   4 ]
  Application - IccTestApp - NOS64_ICC ( 64-bit ) - Release
  Tests: Start
  > Test1155 Start <
          Keys         : 06 10 11 14 11 07 04 12 02 16 13 16 15 04 04 04 04 01 04 04 08 07 15 12
          Min Key value: 01
          Max Key value: 16
          Cipher Text: NOGBD'HCPUCJ/W^\\!GMXOJ^
  Generating DataSet
  Identification
          Cipher: 'NOGB' - Crib: 'HELL' - Keys: 06 10 11 14 - Offset:  0
          Cipher: 'D'HC' - Crib: 'O LO' - Keys: 11 07 04 12 - Offset:  4
          Cipher: 'PUCJ' - Crib: 'RENZ' - Keys: 02 16 13 16 - Offset:  8
          Cipher: '/W^\' - Crib: ' SZX' - Keys: 15 04 04 04 - Offset: 12
          Cipher: '\!GM' - Crib: 'X CI' - Keys: 04 01 04 04 - Offset: 16
          Cipher: 'XOJ^' - Crib: 'PHER' - Keys: 08 07 15 12 - Offset: 20
          Cipher: 'XOJ^' - Crib: 'WINT' - Keys: 15 06 04 10 - Offset: 20
          Cipher: 'XOJ^' - Crib: 'RENZ' - Keys: 10 10 04 04 - Offset: 20
  Deallocates Memory
  Test Completed in 281660 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
  Tests: Start
  > Test1155 Start <
          Keys         : 09 09 05 07 16 04 02 13 02 09 01 10 07 10 12 14 04 06 16 14 11 02 03 14
          Min Key value: 01
          Max Key value: 16
          Cipher Text: ALIK_$NBPLOP'YVV\&SG[JF\
  Generating DataSet
  Identification
          Cipher: 'ALIK' - Crib: 'HELL' - Keys: 09 09 05 07 - Offset:  0
          Cipher: '_$NB' - Crib: 'X CI' - Keys: 07 04 13 11 - Offset:  4
          Cipher: '_$NB' - Crib: 'O LO' - Keys: 16 04 02 13 - Offset:  4
          Cipher: 'PLOP' - Crib: 'RENZ' - Keys: 02 09 01 10 - Offset:  8
          Cipher: 'PLOP' - Crib: 'WINT' - Keys: 07 05 01 04 - Offset:  8
          Cipher: ''YVV' - Crib: ' SZX' - Keys: 07 10 12 14 - Offset: 12
          Cipher: '\&SG' - Crib: 'X CI' - Keys: 04 06 16 14 - Offset: 16
          Cipher: '[JF\' - Crib: 'RENZ' - Keys: 09 15 08 06 - Offset: 20
          Cipher: '[JF\' - Crib: 'PHER' - Keys: 11 02 03 14 - Offset: 20
          Cipher: '[JF\' - Crib: 'WINT' - Keys: 12 03 08 08 - Offset: 20
  Deallocates Memory
  Test Completed in 195219 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
  Tests: Start
  > Test1155 Start <
          Keys         : 02 08 06 15 15 12 15 03 14 12 05 07 03 05 01 01 04 12 09 01 02 03 16 12
          Min Key value: 01
          Max Key value: 16
          Cipher Text: JMJC@,CL\IK]#V[Y\,JHRKU^
  Generating DataSet
  Identification
          Cipher: 'JMJC' - Crib: 'HELL' - Keys: 02 08 06 15 - Offset:  0
          Cipher: '@,CL' - Crib: 'O LO' - Keys: 15 12 15 03 - Offset:  4
          Cipher: '\IK]' - Crib: 'PHER' - Keys: 12 01 14 15 - Offset:  8
          Cipher: '\IK]' - Crib: 'RENZ' - Keys: 14 12 05 07 - Offset:  8
          Cipher: '#V[Y' - Crib: ' SZX' - Keys: 03 05 01 01 - Offset: 12
          Cipher: '\,JH' - Crib: 'X CI' - Keys: 04 12 09 01 - Offset: 16
          Cipher: 'RKU^' - Crib: 'PHER' - Keys: 02 03 16 12 - Offset: 20
  Deallocates Memory
  Test Completed in 193597 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
  Tests: Start
  > Test1155 Start <
          Keys         : 09 15 04 01 08 03 09 10 14 03 01 04 07 03 04 09 16 08 15 16 13 09 03 08
          Min Key value: 01
          Max Key value: 16
          Cipher Text: AJHMG#EE\FO^'P^QH(LY]AFZ
  Generating DataSet
  Identification
          Cipher: 'AJHM' - Crib: 'HELL' - Keys: 09 15 04 01 - Offset:  0
          Cipher: 'G#EE' - Crib: 'O LO' - Keys: 08 03 09 10 - Offset:  4
          Cipher: '\FO^' - Crib: 'PHER' - Keys: 12 14 10 12 - Offset:  8
          Cipher: '\FO^' - Crib: 'WINT' - Keys: 11 15 01 10 - Offset:  8
          Cipher: '\FO^' - Crib: 'RENZ' - Keys: 14 03 01 04 - Offset:  8
          Cipher: ''P^Q' - Crib: ' SZX' - Keys: 07 03 04 09 - Offset: 12
          Cipher: 'H(LY' - Crib: 'X CI' - Keys: 16 08 15 16 - Offset: 16
          Cipher: ']AFZ' - Crib: 'PHER' - Keys: 13 09 03 08 - Offset: 20
          Cipher: ']AFZ' - Crib: 'WINT' - Keys: 10 08 08 14 - Offset: 20
  Deallocates Memory
  Test Completed in 200695 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
  Tests: Start
  > Test1155 Start <
          Keys         : 11 03 14 07 08 14 07 13 13 05 15 01 12 16 01 07 15 11 06 12 03 15 02 04
          Min Key value: 01
          Max Key value: 16
          Cipher Text: CFBKG.KB_@A[,C[_W+EESGGV
  Generating DataSet
  Identification
          Cipher: 'CFBK' - Crib: 'HELL' - Keys: 11 03 14 07 - Offset:  0
          Cipher: 'G.KB' - Crib: 'O LO' - Keys: 08 14 07 13 - Offset:  4
          Cipher: '_@A[' - Crib: 'PHER' - Keys: 15 08 04 09 - Offset:  8
          Cipher: '_@A[' - Crib: 'RENZ' - Keys: 13 05 15 01 - Offset:  8
          Cipher: '_@A[' - Crib: 'WINT' - Keys: 08 09 15 15 - Offset:  8
          Cipher: ',C[_' - Crib: ' SZX' - Keys: 12 16 01 07 - Offset: 12
          Cipher: 'W+EE' - Crib: 'X CI' - Keys: 15 11 06 12 - Offset: 16
          Cipher: 'SGGV' - Crib: 'PHER' - Keys: 03 15 02 04 - Offset: 20
          Cipher: 'SGGV' - Crib: 'RENZ' - Keys: 01 02 09 12 - Offset: 20
          Cipher: 'SGGV' - Crib: 'WINT' - Keys: 04 14 09 02 - Offset: 20
  Deallocates Memory
  Test Completed in 188730 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
  Tests: Start
  > Test1155 Start <
          Keys         : 16 02 07 04 07 07 10 05 06 04 02 16 11 14 10 12 03 07 14 02 13 16 14 15
          Min Key value: 01
          Max Key value: 16
          Cipher Text: XGKHH'FJTALJ+]PT['MK]XK]
  Generating DataSet
  Identification
          Cipher: 'XGKH' - Crib: 'HELL' - Keys: 16 02 07 04 - Offset:  0
          Cipher: 'H'FJ' - Crib: 'O LO' - Keys: 07 07 10 05 - Offset:  4
          Cipher: 'H'FJ' - Crib: 'X CI' - Keys: 16 07 05 03 - Offset:  4
          Cipher: 'TALJ' - Crib: 'RENZ' - Keys: 06 04 02 16 - Offset:  8
          Cipher: '+]PT' - Crib: ' SZX' - Keys: 11 14 10 12 - Offset: 12
          Cipher: '['MK' - Crib: 'X CI' - Keys: 03 07 14 02 - Offset: 16
          Cipher: ']XK]' - Crib: 'PHER' - Keys: 13 16 14 15 - Offset: 20
  Deallocates Memory
  Test Completed in 192771 ms
  > Test1155 End <
  Tests: Completed
SergeyKostrov
 [ Summary - KNL server ]
  Number of OpenMP Threads :    8  Test Completed in 310169 ms
  Number of OpenMP Threads :   16  Test Completed in 161136 ms
  Number of OpenMP Threads :   32  Test Completed in  80065 ms
  Number of OpenMP Threads :   64  Test Completed in  41307 ms  Best time
  Number of OpenMP Threads :  128  Test Completed in  42451 ms  Oversubscription / Processing Saturation
  Number of OpenMP Threads :  256  Test Completed in  43021 ms  Oversubscription / Processing Saturation
  Number of OpenMP Threads :  512  Test Completed in  42787 ms  Oversubscription / Processing Saturation
  Number of OpenMP Threads : 1024  Test Completed in  42839 ms  Oversubscription / Processing Saturation
  Number of OpenMP Threads : 2048  Test Completed in  42878 ms  Oversubscription / Processing Saturation
