Software Archive
Read-only legacy content
17060 Discussions
(Ctrl + Insert) Hotkey Bug
Roy_O_
I'm using Intel XDK version 3900. I noticed that whenever I use the copy hotkey (Ctrl + Insert), it decreases the file font size. Obviously, this is a bug. Using (Ctrl + C) works, but for me it's faster at times to copy/paste with (Ctrl + Insert) / (Shift + Insert).
Namık_Zafer_E_
You can use this extension below
https://github.com/redmunds/brackets-display-shortcuts
In Intel XDK, select Extension Manager, install "Display Shortcuts". After them, open help tab, select "Show Shortcuts". Then you can remove or update any shortcuts by left click. After your edit, you can see your changes on keymap.json
PaulF_IntelCorp
This is a known issue that will be fixed in an upcoming hotfix release.
