Software Archive
Read-only legacy content
17060 Discussions
Custom Build Console Output
Intel_C_Intel
I run a Fortran text translator as a custom build step in a project. I have been unable to obtain any output from the translator when it is invoked in a build process. I can't even tell from the CVF build window if it ran successfully. The translator executes fine from a DOS prompt. It was compiled as a console application. It used to work properly but I can't remember if it was version 5.0 or the MS Power Station 4.0. Any suggestions?
The .PLG file should tell you everything that happened as part of the build.
Steve
