- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I would like to know whether we can change the frequency of the intel multi-core processors individually. I have Intel Core2Duo CPU T5750 which has 2 cores. When I run cpufreq-info in Linux I get to know that both the cores will run in the same hardware frequency. Please find cpufreq-info output below(Relevant data shown)
$ cpufreq-info
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0 1
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 10.0 us.
hardware limits: 1000 MHz - 2.00 GHz
available frequency steps: 2.00 GHz, 1.67 GHz, 1.33 GHz, 1000 MHz
analyzing CPU 1:
CPUs which need to have their frequency coordinated by software: 1
Hence by above output I expect both cores to vary its frequency in a synchronous fashion.
But when I tried to check the frequency of each core by using the information in /proc/cpuinfo, I see that the cores are varying its frequency individually. The command I used and its output are below:
$ while true; do grep -e "cpu MHz" /proc/cpuinfo; echo "===";sleep 0.1; done
cpu MHz : 1000.000
cpu MHz : 1000.000
cpu MHz : 2000.000
cpu MHz : 1000.000
cpu MHz : 1000.000
cpu MHz : 1000.000
cpu MHz : 1000.000
cpu MHz : 1000.000
cpu MHz : 1000.000
cpu MHz : 2000.000
cpu MHz : 1000.000
cpu MHz : 1000.000
The above output can be more neatly obtained using watch command as below:
$ watch -n 0.1 grep \"cpu MHz\" /proc/cpuinfo
My questions are:
1) Can someone explain why the cores change the frequency individually even though the cpurfreq-info says that both the cores run at the same hardware frequency? Am I missing something?
2) Does latest intel multi-core chips have per-core DVFS? Kindly let me know.
3) Can voltage and frequency can be changed independent of each other in latest multicore processors using EIST (Enhanced Intel Speed Step Technology)?
Kindly let me know your comments...
Thanks for your time,
Karthik.V.M.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Karthik,
You may want to repost this on the Community for processors here: http://communities.intel.com/community/tech/processors
Regards, Hal G
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of others.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Hal,
Thanks a lot for your assistance. I will repost it there.
karthik
