Software Archive
Read-only legacy content
17060 Discussions
Debug module build and install hit or miss.
Silviu_I_
Every once in a while, the debug module will claim that basically everything's new (all the plugins) and ask to build a whole new module by pressing start.
So, I do it and it uploads, builds, downloads and installs.
Except it doesn't because once it's done it goes back to telling me all the plugins are new and I need to build a whole new debug module.
Is there a way around this? The debug module apk is there in the Intel XDK's files but it's either not being installed on the device or... something.
Ideas?
Quick edit: Actual build page and functionality works perfectly fine but I'd prefer the debug page for some tasks.
EDIT: Turns out that if I had checked the adb logs properly, I would have seen an install issue which pointed me right at the problem.
Amrita_C_Intel
Can you provide some screenshots?
Which XDK version are you using?
Silviu_I_
Nevermind it was a build issue in the code (a permission was being issued to the wrong app id because you guys don't support gradle).
Don't worry about it for now.
