Software Archive
Read-only legacy content
17060 Discussions
Delete project from the cloud
Lorenzo_B_1
Hi there,
I was wondering how I can delete my projects from the cloud in order to clean the old test projects. Thanks!
PaulF_IntelCorp
See the link to App Center on this page and use the little trash can icon associated with the app you want to delete when you get there (log into App Center with your XDK userid and password).
Lorenzo_B_1
Thanks for the answer but this don't work.
When I get on https://appcenter.html5tools-software.intel.com/default.aspx only a text is shown that say:
Thank you for using the Intel® XDK.
If you are accessing this service from AppPreview, you may close the sign in window.
and nothing else..
What can I do?
Ad
New Contributor III
I have/had the same problem.
It looks like you have to open the App Center twice!
My solution:
Step 1: open App Center and log in with your account, result: [message: Thank you for using the Intel® XDK.]
Step 2: open a new tab in your browser (don't logout in the previuous tab!) and open App Center again. Now you will see the App Center with recycle bin.
Lorenzo_B_1
Wow thanks! I hope that sooner or later will solve this error
PaulF_IntelCorp
I just spoke with the responsible engineer and he is working on a fix to the issue. It will not show up immediately, but will get changed. In the meantime, please continue to use the procedure outlined by @ad above. Sorry about the strangeness.
Rowan_S_
Hi - I am also experiencing this problem except that even opening two tabs just presents me with two instances of the "Thanks" message.
Brandon_K_Intel
Please use the following link after you have logged into app center. This should allow you to navigate to the correct AppCenter page.
 https://appcenter.html5tools-software.intel.com/csd/controlpanel.aspx
The issue is after you login you are routed to the thank you page which exists here (https://appcenter.html5tools-software.intel.com/default.aspx). You have to change the end of the url to /csd/controlpanel.aspx until we have this resolved.
POH_YEE_W_
Hi, I followed a video to start a project and to open an Intel xdk project, called Semanticelements. I couldn't find it. Where is it? Please assist. Thanks.
This is the transcript:
  1. Throughout this course, you will be provided Intel XDK projects in exercises or just to experiment with.You’ll download the project from edX,and in this video, we will see how to import that project into Intel XDK.Navigate to the project’s tab in Intel XDK and select ‘open an Intel XDK project’.Navigate to the location of your downloaded project.Semantic elements is a project that I have downloaded.Inside the project tree you will find the file name with the extension ‘.xdk’.Select that file to import the project.You can make any html5 related changes in the develop tab, and selecting the HTML file.
PaulF_IntelCorp
Can you provide a pointer to the video that mentions this project? We've never had any sample project named "semantic elements."
