Software Archive
Read-only legacy content
17060 Discussions
Depth Measurement
mathieu_a_
I'm trying to read depth measurement, I tried using sample->depth.
But I can`t figure out the depth format/how to interpret the data.
I'm trying to analyse all the depth for a single frame and find the closest point in the frame.
Any help would be appreciated.
samontab
Valued Contributor II
Ignore any value of 0, and then get the smaller value in the frame. That's the closest point.
mathieu_a_
I'm using the following code to print the 250th depth value, but I can`t figure out the unit used to represent the depth.
PXCCapture::Sample *sample = sm->QuerySample();
PXCImage *depthFrame = sample->depth;
PXCImage::ImageData imgData = {};
unsigned short* points_buf;
depthFrame->AcquireAccess(PXCImage::ACCESS_READ, PXCImage::PIXEL_FORMAT_DEPTH_RAW, &imgData);
points_buf = (unsigned short*)imgData.planes[0];
if (sample->depth)
	pxcCHAR line[256];
	swprintf_s<sizeof(line) / sizeof(line[0])>(line, L"Depth=%d", points_buf[250]);
	UpdateStatus(line);
/* Resume next frame processing */
sm->ReleaseFrame();
samontab
That format is device specific. Try using either PIXEL_FORMAT_DEPTH or PIXEL_FORMAT_DEPTH_F32. Those are in mm.
Have a look here:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?pixelformat_pxcimage.html
qyan
   I want to convert the 16-bit depth data to millimeter.what is the formula? Is that " *0.0001"? Thank you for helping me!
qyan
   I want to convert the 16-bit depth data to millimeter.what is the formula? Is that " *0.0001"? R200 /outdoor.Thank you for helping me.
