Software Archive
Read-only legacy content
17060 Discussions
Depth coordinate in QueryVertices() function
Amit_T_
In IQSampleTool application, the specified function returns a vertices array of 3D points (PXCMPoint3DF32[]). These points suppose to have 3 'single' fields - x,y,z.
However, the z field of all points of the vertices array retrieved by the function always seems to have an integer value. Is it necessarily the case? Do these vertices points always have an integer z value?
jb455
Valued Contributor II
Yes they do, annoyingly! If you want float values for depth you'll have to do depthImage.AcquireAccess() with a float pixel format then use depthData.ToFloatArray(), and use these z values along with the x & y you get from the vertices.
Amit_T_
I am trying to follow your instructions, but the change from depthData.ToUShortArray() to depthData.ToFloatArray() cause this runtime exception: "System.AccessViolationException - Attempted to read or write protected memory".
Do you know what is it about and how to resolve it?
jb455
Are you using PXCMImage.PixelFormat.PIXEL_FORMAT_DEPTH_F32?
Amit_T_
Yes. This format changes the pixels resolution from 640*480 to 1280*480.
But the same exception is thrown when using both formats (PIXEL_FORMAT_DEPTH_F32 and PIXEL_FORMAT_DEPTH).
Attached is the exception details.
Amit_T_
We solved the problem. Sorry for the trouble.
The problem was dividing by sizeof(float) instead of sizeof(ushort)...
Now it's working, thank you very much.
jb455
Hmm, not sure what that could be.. I presume dpixels is of float[] type? My code is in bits at the moment so I can't test for you but I don't remember seeing this error before. Perhaps someone else can help?
Dmitry_Z_Intel
Please note this rounding behavior of QueryVertices() was fixed for future SDK releases.
Amit_T_
Great, thank you.
jb455
That's good to hear! Is there anything you can share with us as to when we can expect the next release?
