Software Archive
Read-only legacy content
17060 Discussions
Devkit setup - wireless connection?
Conor_B_
Hi guys,
I'm following the IoT Dev kit guide
https://software.intel.com/sites/default/files/managed/2a/e9/Intel-DeveKit-Tutorial-Guide.pdf
On page 7, it indicates to connect the host pc and the galileo to a router. I have a wireless internet connection, can you set it up without a wired connection?
Conor
Matthias_H_Intel
no time to put full details. Just some hints:
- you obviously would need to have a wireless adapter attached to your Galileo board PCIe
- you'd have to configure for your wireless environment [connman configuration file]and make sure WiFi is enabled on startup (rfkill unblock -> dependent on which version of image you are running either init.d or systemd script)
Good luck,
Matthias
Conor_B_
Hello Matthias,
Thank you for your reply. I have my Galileo connected to Wifi with a wireless adapter.
To be honest, I am completely new to Linux and don't really know how to configure the wireless environment as you describe. If you had the time, I would really appreciate if you could perhaps post a "how to guide" of how to set up the IoT Dev kit guide with a wireless connection.
I'm sure it would benefit other people also who do not have a wired connection but would like to follow the IoT examples on the website.
Many thanks
Conor
Matthias_H_Intel
I plan to write a blog in near future. Pls grant me some more time to write it up
Conor_B_
Hello Matthias,
That would very very helpful.
Many thanks
Conor
Stev
Hello Conor and Matthias,
Could you please post the instructions of how to set up the devkit with a wireless connection. It would be very help as I would like to use it but do not have access to a wired router as described in the getting started guide.
Cheers
Stev
KMill10
Valued Contributor II
Using a Serial terminal (PuTTY, TeraTerm etc) connected to the 3.5mm Jack you can follow the instructions on my blog at www.spider-e.com/wp for getting WiFi running on Galileo. Blog post is here.
You won't need to download anything as the drivers for some Intel cards are already in the IoT image.
Matthias_H_Intel
Kenny nicely described how to setup Intel® Galileo low level Yocto uses the connection manager connman which allows to configure wireless access at a higher level. Pls find my blog on that at https://software.intel.com/en-us/blogs/2014/04/25/wireless-galileo-on-yocto-linux-iot-devkit-image.
