Software Archive
Read-only legacy content
17060 Discussions
Displaying Image in Dialog Box
Intel_C_Intel
I am learning Quick Win and am trying to display a Text and Image using the following commands:
retlog = DlgSet(dig, DC_EDIT1, Test' )
retlog = DlgSet(dig, DC_STATIC1, IDB_BITMAP2)
The text works fine, but not the static image. I thought of trying DLGSENDCTRLMESSAGE, but not sure what T_MSG in documentation refers to:
retint = DLGSENDCTRLMESSAGE (dlg, IDC_STATIC1, T_MSG???,0,IDB_BITMAP2)
I would appreciate any help on this.
Rajesh
Jugoslav_Dujic
Valued Contributor II
Hi Rajesh,
The message you're looking for is STM_SETIMAGE, with arguments IMAGE_BITMAP and hImage; hImage, however, is Windows handle of the bitmap. You can load a bitmap from resource
using
USE DFWIN
hImage=LoadBitmap(GetModuleHandle(NULL), MAKEINTRESOURCE(IDB_BITMAP2))
However, this makes sense only if you want to change the bitmap at run-time; you can add a bitmap into the dialog at design-time, from resource editor -- just add a "Picture" control from the "Controls" toolbar,
select "Type: Bitmap" in its "Properties" dialog, and then select bitmap's ID from the "Image" combo. Even if you use DlgSendCtrlMessage, the control you want to assign the bitmap must be of type "Picture" as described above.
Jugoslav
Intel_C_Intel
Jugoslav,
Thanks. Yes, I want to change the image during run time. And so I tried:
hImage=LoadBitmap(GetModuleHandle(Null), MAKEINTRESOURCE(IDB_BITMAP2))
n = DLGSENDCTRLMESSAGE(dlg,idc_static1, STM_SETIMAGE,
IMAGE_BITMAP,hImage)
n = DlgModal(dlg)
But I get a message to the effect that STM_SETIMAGE and IMAGE_BITMAP are not defined. Should I be declaring them as some type, or did I interpret your instructions incorrectly?
Rajesh
Jugoslav_Dujic
You did interpret them correctly; however, the "compilability" of the code depends on version of CVF you have: older versions (up to 6.0 AFAIK) don't have complete declarations in DFWIN module. Here are the correct declarations for names in question which you may include in a separate module or declare them directly in the code:
INTEGER,PARAMETER:: STM_SETIMAGE        =#0172
INTEGER,PARAMETER:: STM_GETIMAGE        =#0173
INTEGER,PARAMETER:: IMAGE_BITMAP            =0
INTEGER,PARAMETER:: IMAGE_ICON              =1
INTEGER,PARAMETER:: IMAGE_CURSOR            =2
INTEGER,PARAMETER:: IMAGE_ENHMETAFILE       =3
INTEGER,PARAMETER:: LR_DEFAULTCOLOR         =#0000
INTEGER,PARAMETER:: LR_MONOCHROME           =#0001
INTEGER,PARAMETER:: LR_COLOR                =#0002
INTEGER,PARAMETER:: LR_COPYRETURNORG        =#0004
INTEGER,PARAMETER:: LR_COPYDELETEORG        =#0008
INTEGER,PARAMETER:: LR_LOADFROMFILE         =#0010
INTEGER,PARAMETER:: LR_LOADTRANSPARENT      =#0020
INTEGER,PARAMETER:: LR_DEFAULTSIZE          =#0040
INTEGER,PARAMETER:: LR_LOADMAP3DCOLORS      =#1000
INTEGER,PARAMETER:: LR_CREATEDIBSECTION     =#2000
INTEGER,PARAMETER:: LR_COPYFROMRESOURCE     =#4000
INTEGER,PARAMETER:: LR_SHARED               =#8000
!DEC$OBJCOMMENT LIB: 'User32.lib'
INTERFACE
      INTEGER(4) FUNCTION  LoadImageA(hInst,lpszName,uType,cxDesired,    &
                                     cyDesired,fuLoad)
      !MS$ATTRIBUTES STDCALL, ALIAS : '_LoadImageA@24' :: LoadImageA
      INTEGER                 hInst
      INTEGER                 lpszName
      INTEGER                 uType
      INTEGER                 cxDesired
      INTEGER                 cyDesired
      INTEGER                 fuLoad
      END FUNCTION LoadImageA
END INTERFACE
With declarations above, replace LoadImage with LoadImageA in the code.
(uh, it's difficult to explain why renaming is necessary).
One more note: be aware that DlgSendCtrlMessage (as far as I know) works only from callback functions (the ones you register with DlgSetSub);
it won't work in the same routine where you call DlgInit...DlgModal. If you
want to set the bitmap initially in the dialog, make a dialog "startup" routine, in the following way:
iSt=DlgInit(...
iSt=DlgSetSub(Dlg, IDD_DIALOG_1, OnDlgInit)
SUBROUTINE OnDlgInit(Dlg, ID, iAction)
iSt=DlgSendCtrlMessage(...
END SUBROUTINE
Jugoslav
