We've been able to reproduce the problems using a Motion Computing LS800 computer (http://www.motioncomputing.com/resources/LS800_datasheet.pdf) and a 1680 x 1050 monitor, using Intel drivers as provided at http://www.motioncomputing.com/support/driver_download_800_vista.asp.
Under Windows XP, it was possible to use the Intel Graphics Media Accelerator Driver for Mobile utility to set a 1680 x 1050 mode for the computer, and docking worked fine: when un-docking the display resolution reverted automatically to the 800 x 600 resolution of the LS800's screen, and on re-docking the display resolution returned automatically to the 1680 x 1050 resolution of the external display.
Under Vista, docking initially seems to work fine. The login screen for Vista appears in 1680 x 1050, and so does the desktop initially after logging in. However, as the startup items get loaded, the external display changes spontaneously to 800 x 600. Using the Intel Graphics Media Accelerator Driver for Mobile utility one can set the display manually to 1680 x 1050, but under Windows XP this used to occur automatically.
After un-docking the computer does eventually settle into 800 x 600, but only after several rounds of blakning out the display momentarily. The transition using Windows XP was not so rocky.
There seems to be a major problem with Vista communicating with the Intel graphics drivers. Most bothersome is that Windows Mobility Center's External Display section always reports "No display attached", even when a display is attached.
These issues are a big annoyance for mobile users who want to use a small computer as a mobile solution and get full functionality by docking the computer at their desk.
Is there some way to fix this problem, or should we be telling customers that the 915GMS does not deliver in Vista the functionality that it had with Windows XP?
Intel is discontinuing maintenance of the WindowsVista graphics drivers for the Intel945G/945GM Express Chipsets after the PV15.8 release
PV15.8 will be the last release to support Intel 945G/GM skus for Windows* Vista
Intel945G Express Chipset
Intel945GC Express Chipset
Intel945GZ Express Chipset
Mobile Intel940GML Express Chipset
Mobile Intel943GML Express Chipset
Mobile Intel945GM Express Chipset
Mobile Intel945GMS Express Chipset
PV stands for "production version". The released 15.8 drivers is what this refers to, as opposed to "PC" or "Production Candidate". Chuck's quote came from a presentation given to OEMs/ODMs and that's why it contains the PV moniker.
Actually, though, I thought there never were any WDDM drivers for 915G, only XPDM. This is a long-standing issue that I don't want to ressurrect here. In fact, at the website you list, the drivers available are the 14.25 series for XP. So you're dealing with the same drivers in any case between XP and Vista; the problems you're experiencing are some kind of Vista-specific interaction. Chuck is likely correct to point you to Intel Support-- 915G is 4-5 generations back in graphics and there's not much modern work done on those drivers. If anyone can help it's the support folks.
Both OEMs and Microsoft gave the go-ahead for upgrading systems with the 915G drivers to Vista. To many, this suggested that available drivers were compatible with Vista. The poor experience that people had upgrading systems to Vista accounts for a lot of the poor reputation that Vista has, and that has depressed sales of new equipment since many people have concluded that Vista is an albatross.
If Intel thought it would increase sales of new equipment by declining to make Vista-compatible drivers for such hardware it should have announced clearly which chipsets would be supported for Vista. Instead, the result was that people are sticking with XP.
"I don't think the 15.8 driver will work with 915G" is what I'm telling you.
The XP drivers are Vista-compatible, which is why they are suggested by your supplier; Vista is supposed to run all XPDM drivers.
intel@simulconsult.com:
I hope you have some spare time testing things:
There is a knowledge base article "The resolution of an external display may unexpectedly change when you log on to a portable computer that is running Windows Vista" related to this:
http://support.microsoft.com/kb/941413/en
Some people fix it by disabling Transient Multimon Manager (TMM) altogether:http://www.vistax64.com/tutorials/115320-transient-multimon-manager-tmm.html
On other systems it helps to disable Pivot Software or Pivot Services.
If all that doesn't help you might want to try MultiRes (don't know whether Vista compatible) to force a particular resolution by hotkey:
http://www.entechtaiwan.com/util/multires.shtm
If you're still not satisfied and very adventurous you might want to try IEGD 8.0:
http://www.intel.com/design/intarch/swsup/graphics_drivers.htm
However these require advanced computer skills and most likely will not satisfy everybody. IEGD drivers very likely break other use cases (e.g. standby/suspend/hibernate). And I don't think they support docking at all.
I'd be glad to try to "disable Pivot Software or Pivot Services" but I don't know what this means. I searched on http://www.google.com/search?q=%22Pivot+Services%22+vista and the #1 search result was this page.
I will also check out MultiRes.
IEGD 8.0 seems like the sort of thing the Hardware manufacturer should be doing, but doesn't seem like end users should be fiddling with.
I still don't know what "Pivot Software or Pivot Services" are so I haven't tried that.
MultiRes does not appear to be what we need - it seems to be just a fast way of resetting manually, something the Intel utility also does manually (resetting was automatic under XP).
Given the (unfortunate) fact that intel no longer maintains the drivers, it gives you the functionality of switching to particular resolutions by hotkey. That's faster than invoking task bar / some icon / click right mouse button etc. You mentioned your display switches spontanously to 800 x 600 in particular cases and this is a possible walkaround to enforce 1650 x 1080 by a single key press.
correct.
Software that turns the windows desktop 90, 180, 270, 0 if you turn the screen:
http://www.portrait.com/us/products/pp_overview.html
http://www.entechtaiwan.net/util/irotate.shtm
Sometimes software of this kind gets installed if you attach a new display and install its monitor drivers (yes, monitors may have drivers).
I figured in some cases the privot software interacts in with display driver in a way that spontanous resolution changes occur. In these cases it help to deinstall the software (or disable their service). You may also check whether your intel driver includes pivot functionality and may try to disable this feature. It helped in one case I had.
