Hi All,
I want to show an external url eg(http://codzz.com/mob.aspx) inside iframe and there is a button to download file on click, But the download button dose not work inside the iframe..
Is there any solution to fix this error?
Thanks in Advance
Ajith
- Tags:
- HTML5
- Intel® XDK
Thanks for your reply, Please find my below code. it works fine in emulator and not in devices.
Sample downloaded from https://github.com/gomobile/sample-url-app/blob/master/www/index.html
<!DOCTYPE html> <html> <!-- * Please see the included README.md file for license terms and conditions. --> <head> <link rel="stylesheet" type="text/css" href="app_framework/css/af.ui.min.css"> <link rel="stylesheet" type="text/css" href="app_framework/css/icons.min.css"> <meta charset="UTF-8"> <title>Blank App Designer Cordova Web App Project Template</title> <meta http-equiv="Content-type" content="text/html; charset=utf-8"> <!-- * The "meta viewport" tag (below) helps your app size appropriately to a device's ideal viewport. * Note that Windows device viewports work better when initialized using the @viewport CSS rule. * For a quick overview of "meta viewport" and @viewport, see this article: * http://webdesign.tutsplus.com/tutorials/htmlcss-tutorials/quick-tip-dont-forget-the-viewport-meta-tag * To see how it works, try your app on a real device with and without a "meta viewport" tag. * Additional useful references include: * http://www.quirksmode.org/mobile/viewports.html * http://www.quirksmode.org/mobile/metaviewport/devices.html * https://developer.apple.com/library/safari/documentation/AppleApplications/Reference/SafariHTMLRef/Articles/MetaTags.html --> <!-- <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1"> --> <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no"> <!-- <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=yes, minimum-scale=1, maximum-scale=2"> --> <style> /* following three (cascaded) are equivalent to above three meta viewport statements */ /* see http://www.quirksmode.org/blog/archives/2014/05/html5_dev_conf.html */ /* see http://dev.w3.org/csswg/css-device-adapt/ */ @-ms-viewport { width: 100vw ; min-zoom: 100% ; zoom: 100% ; } @viewport { width: 100vw ; min-zoom: 100% zoom: 100% ; } @-ms-viewport { user-zoom: fixed ; min-zoom: 100% ; } @viewport { user-zoom: fixed ; min-zoom: 100% ; } /*@-ms-viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; } @viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }*/ </style> <link rel="stylesheet" href="css/app.css"> <link rel="stylesheet" type="text/css" href="css/index_main.less.css" class="main-less"> <!-- IMPORTANT: Do not include a weinre script tag as part of your release builds! --> <!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work below --> <!-- <script src="http://debug-software.intel.com/target/target-script-min.js#insertabiglongfunkynumberfromthexdkstesttab"></script> --> <!-- Recommended location for your JavaScript libraries --> <!-- These library references (below) are just examples to give you the general idea... --> <!-- <script src="lib/mc/hammer.js"></script> --> <!-- <script src="lib/ft/fastclick.js"></script> --> <!-- Uncomment this script element if you convert your "Cordova web app" to a "Standard HTML5 web app" --> <!-- <script type="text/javascript" id="xdkJSdevBrowser_"> window.dev = window.dev || {} ; // object used by init-dev.js, which detects various ready events dev.BROWSER = 500 ; // msecs, in non-Cordova app we don't care about "deviceready" events </script> --> <!-- * cordova.js is a phantom lib for "Cordova HTML5 web app," it does nothing in a "Standard HTML5 web app" * Seeing a "Failed to load resource: net::ERR_FILE_NOT_FOUND" message caused by this "cordova.js" script? * The cordova.js script is required if you convert your "Standard HTML5" project into a "Cordova" project. * You can safely ignore the error or comment out this line if you will not be developing a Cordova app. --> <script src="cordova.js" id="xdkJScordova_"></script> <script src="js/app.js"></script> <!-- for your event code, see README and file comments for details --> <script src="js/init-app.js"></script> <!-- for your init code, see README and file comments for details --> <script src="xdk/init-dev.js"></script> <!-- normalizes device and document ready events, see file for details --> <script src="js/main.js"></script> <!-- You may substitute jQuery for the App Framework selector library. See http://app-framework-software.intel.com/documentation.php#afui/afui_jquery --> <script type="application/javascript" src="app_framework/appframework.js"></script> <script type="application/javascript" src="app_framework/appframework.ui.js"></script> </head> <body id="afui" onload="onDocLoad()"> <!-- IMPORTANT: Do not include a weinre script tag as part of your release builds! --> <!-- Place your remote debugging (weinre) script URL from the Test tab here, if it does not work above --> <!-- <script src="http://debug-software.intel.com/target/target-script-min.js#insertabiglongfunkynumberfromthexdkstesttab"></script> --> <div id="content" class="uwrap"> <div class="upage vertical-col left panel" id="mainpage" data-header="none" data-footer="none"> <div class="widget uib_w_1 d-margins iframe-size" data-uib="media/iframe" data-ver="0"> <iframe seamless="seamless" id="IDZ_iFrame" src="http://codzz.com/mob.aspx"></iframe> </div> </div> </div> </body> </html>
No, It dosent work. I have tried AppBrowser plugin too.
<script src="cordova.js"></script>
<script>
function openwin(){
window.open('http://codzz.com/mob.aspx', '_blank', '');
</script> <button onclick="openwin()">window open</button>
Again I have added header in my aspx page, still same problem.
string fileName = "mmmmm.mp3";
string filePath = Server.MapPath("~/mmmmm.mp3");
Response.Clear();
Response.ClearHeaders();
Response.AddHeader("Access-Control-Allow-Origin", "*");
Response.AppendHeader("Access-Control-Allow-Methods", "OPTIONS,POST,GET");
Response.AppendHeader("Access-Control-Allow-Headers", "X-File-Name,X-File-Type,X-File-Size");
Response.ContentType = "audio/mpeg";
Response.AddHeader("content-disposition", "attachment; filename=" + fileName);
Response.WriteFile(filePath);
Response.Flush();
Response.End();
Gabriele,
please, kindly show the project sample that work for iframe. cos i am still finding difficulty using iframe.
thank you.
Gbenga
Topic Options
