Software Archive
Read-only legacy content
17060 Discussions
Downloaded CSR cannot be use in Apple for certificate generation
khin_sin_c_
I am doing a build using Cordova Hybrid Mobile App platform for iOS. I downloaded the CSR in the build and upload it to the iOS developer center while try to generate the certificate. However, after upload the CSR to iOS developer center, the generate button still disable. I cant continue to generate the certificate.
Any idea?
khin_sin_c_
sorry for realize this is the IE issue. Using google chrome has no issue to click on the generate button
khin_sin_c_
After i have generate the certificate from iOS dev center, i try to upload it to the xdk. i was prompt "The certificate was not created with the Certificate Signing Request.". So what should i do?
Anusha_M_Intel1
Your CSR might have become outdated. Could you try downloading the CSR from the build tab again and promptly re-generate the certificate?
If you don't already have the link to instructions: https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
