I am trying to figure out how to get my second display (Toshiba 30HF84 HDTV) to use wide screen resolutions as a second monitor using the S-Video. I have read some of the other posts and downloaded the DTD Calculator and used a linux modeline I found for the tv to try and fix it. I am confused though. I am not sure how to change the second monitor so it is widescreen when it is my extended desktop. Is there a way to do this? Having it make use of the 1080i or any sort of widescreen would rock.
Here is the modeline I found
Modeline "1280x720" 74.160 1280 1352 1392 1648 720 725 730 750 -hsync -vsync
which translates to a Calculated DTD of
F8 1C 00 70 51 68 0F 10 48 28 22 00 00 00 00 00 00 98
It is using the Generic Television driver and I have a intel 945GM chipset. My computer is a Dell E1505. Here is the info on the TV using mon info... though I am not too sure what to make of it.
Monitor
Windows description......... Generic Television
Manufacturer................ PNP
Plug and Play ID............ PNP09FE
Serial number............... n/a
EDID data source............ Registry (stored)
Manufacture date............ 1990
EDID revision............... 0.0
Display type and signal..... Analog 0.700,0.300 (1.0V p-p)
Sync input support.......... n/a
Screen size................. n/a
Power management............ n/a
Color characteristics
Display gamma............... 1.00
Red chromaticity............ Rx 0.000 - Ry 0.000
Green chromaticity.......... Gx 0.000 - Gy 0.000
Blue chromaticity........... Bx 0.000 - By 0.000
White point (default)....... Wx 0.000 - Wy 0.000
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... n/a
Vertical scan range......... n/a
Video bandwidth............. n/a
Extension blocks............ n/a
Timing recommendation #1.... 720x480 at 60Hz
Modeline................ "720x480" 27.020 720 736 797 858 480 489 494 525 -hsync -vsync
Timing recommendation #2.... 720x480 at 60Hz
Modeline................ "720x480" 26.130 720 730 799 880 480 481 483 495 -hsync -vsync
Timing recommendation #3.... 720x576 at 60Hz
Modeline................ "720x576" 32.400 720 732 795 864 576 581 585 625 -hsync -vsync
Timing recommendation #4.... 720x576 at 60Hz
Modeline................ "720x576" 32.660 720 744 815 912 576 577 579 597 -hsync -vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
720 x 480 at 60Hz - PNP
720 x 576 at 60Hz - PNP
800 x 600 at 60Hz - VESA
1024 x 768 at 60Hz - VESA
Raw EDID base
00: 00 FF FF FF FF FF FF 00 41 D0 FE 09 00 00 00 00
10: 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00
20: 00 00 00 21 08 00 01 01 01 01 01 01 01 01 01 01
30: 01 01 01 01 01 01 8E 0A D0 8A 20 E0 2D 10 10 3D
40: 95 00 00 00 00 00 00 18 35 0A D0 A0 20 E0 0F 10
50: 0A 45 12 00 00 00 00 00 00 18 A8 0C D0 90 20 40
60: 31 20 0C 3F 54 00 00 00 00 00 00 18 C2 0C D0 C0
70: 20 40 15 20 18 47 12 00 00 00 00 00 00 18 00 4B
Display adapter
Adapter description......... Mobile Intel 945GM Express Chipset Family
Adapter device ID........... 0x27A68086
Display settings............ 1024x768, 32bpp
User/computer information
Registered user name........ Kyle Weaver
Registered organization..... TiGer Inc.
Network user name........... Kyle
Network computer name....... TIGER
Windows version ............ Windows XP
Windows build .............. 5.01.2600 Service Pack 2
Installation date .......... 1/13/2008 12:00:00 PM
I'm am pretty good with computers and understand how to edit my registry/install drivers. Just not quite sure what to change if I need to. Any help would be most appreciated!!
Kyle
Monitor
Raw EDID base
Display adapter
Kyle
I don't think this is going to work in the way you want it to. Svideo only transmits 480i (576i for PAL); even if you somehow get the TV to send 1280x720 your TV won't accept it.
That is quite unfortunate. What about just putting it in wide screen in general? Maybe at a lower resolution. Just so everything is not disproportionate.
