Software Archive
Read-only legacy content
17060 Discussions
ESC key problem in the default forums Editor - text disappears if Esc pressed
SergeyKostrov
Valued Contributor II
*** ESC key problem in the default forums Editor - text disappears if Esc pressed *** I'd like to address one long existing problem related to the Editor. In the default forums Editor any text disappears if Esc pressed accidentally. I don't think this is a correct action for the editor and the problem needs to be fixed.
Harold_G_Intel
Hi Sergey,
I will check into this.
What browser/version/OS are you using?
Regards, Hal
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of other
SergeyKostrov
>>...What browser/version/OS are you using?.. Windows 7 SP1 IE version 10 ( All MS Updates for both ) Actually, It is possible to reproduce that problem with any IE after version 8! Once again, it is a very old problem.
Harold_G_Intel
I have created an engineering ticket for this and will keep you updated.
Regards, Hal
SergeyKostrov
Hi Hal, Here is an additional note: A Disable Rich-Text needs to be clicked first in order to reproduce the problem and please update your request. Almost all my posts are done in a simple text mode, that is when Rich-Text mode of the Editor is disabled.
