Software Archive
Read-only legacy content
17060 Discussions
Eclipse Problem ( Galileo Gen 2 )
Tomasz_J_
Hi!
I start my adventure with Galileo Gen 2. I did the C / C ++ Eclipse guide and i stuck: /
I have a problem with Eclipse. For the first time everything worked but the second time this error appeared. I do not know how to handle it?
Thank you in advance for your help.
Dallas_P_
Several possibilities but most likely is the first time you ran it on the target you neglected to terminate the process.  If the LED is still blinking reboot the target and try again.  Another option is to click over on the Debug perspective and see if the process terminate or not.  If not terminate it.
Oh course you probably figured this out already.
KDP
Dallas_P_
KDP
