Software Archive
Read-only legacy content
17060 Discussions
Eclipse or Android studio
Derp_K_
Hi
Which one is better for starting ?
Amr_S_
It depends on your application
but
i think eclipse is better for starting
Derp_K_
but
Thanks Amr
what's  the difference between them ?
Amr_S_
As i know , Android studio is more generally as it combines the Eclipse ADT project into a single file or project
but you can also search to get more information
i hope that i helped you
Derp_K_
Thank you Amr
Eduardo_C_Intel
Hi Derp,
Currently I believe that Android Studio is one of the best tools for Android Development, even if you are a beginner. It is easy to install, all the tools are already integrated in the IDE, there are always updates with new features and bugfixes, it is light compared to Eclipse, has a better access to sample code projects and many other benefits.
Besides google already dropped support for ADT as you can see here.
So if you want to start with Android development and be up to date with the current developer tools I would go with Android Studio.
Good Luck!
Derp_K_
I think that's what I look for
Thank you Edu Carrara
Derp_K_
Excuse me if you have good links for starting with Android Studio (Tutorials) please post it
Eduardo_C_Intel
I don't know what exactly you are looking for but to start with Android and consequently with Android Studio check the Udacity courses
- Android Development for Beginners
- Developing Android Apps
These courses are awesome! If you are looking for something specific about Android Studio there are tons of videos on youtube.
Derp_K_
Great , Thanks
Eduardo_C_Intel
You are welcome :)
Derp_K_
i faced this error during installation
Derp_K_
Although , i added the system variable as they said
Eduardo_C_Intel
Derp you must have a Java JDK (Java Development Kit) installed on your machine. From what I can see in your screenshots you are trying to use a Java JRE (Java Runtime Environment).
Derp_K_
Oh yeah sorry :D , i'm downloading JDK and i will try
Eduardo_C_Intel
No problem! :)
Derp_K_
It's stuck on this screen
Does it take a long time ?
Eduardo_C_Intel
Yes! It takes a long time because it is downloading Android SDK files... It will depend on the speed of your connection :P
Derp_K_
How can i edit this strip
Eduardo_C_Intel
This "strip" is the android toolbar or action bar. :P
Well if you want to change the application name you should check the string.xml on resources directory. If you want to change the color and stuff you should check for resources on toolbar styling, check the toolbar and action bar sections here for example.
Derp_K_
Great :P
