Software Archive
Read-only legacy content
Edison+Arduino+MRAA+Python works only first time
Mircea_D_
very strange problem
i have an Edison Arduino board,
i installed ubilinbux on it
also installed lib mraa (python)
i tried both samples GPIO in and out
https://github.com/intel-iot-devkit/mraa/tree/master/examples/python
blink-io8.py and hello_isr.py
if in unplub both usb cables from the arduino, reconect back login and run the sample everything works perfect
if i start killing the sample (ctrl+Z) or kill python process or close python interpreter, and try again to run the sample, nothing works
let me explain nothing works:
the isr sampel si not working at all
but the gpio out sample, if i use pin 10 instead of turning on the led i added on pin ten (like it was doing immediately after power on) now some green led closer to the 6 pin header (3x2) is turning on and off, and if i mess with this led, i lose the wifi/network connectivity (cannot ping in or out to the edison linux) but the putty over the com port works fine
anyone any ideas or explanation into how this edison works and what gets messed up and eventually how it can be made again to work. (i tried to press all the 5 buttons present on the board and 1 to 4 they are not making the problem go away, anyway read teh docs about them and those buttons have all kind of functionality, and 5 resets the linux but still does not make io work, i need to power down completely the board and power it back on to get io back working)
​hope this problem with the IO getting all messed up after first sample run makes sense to anyone.
Mircea_D_
wifi issue after first mraa python script gets run (till that moment all works perfect)
samontab
Valued Contributor II
Hi Mircea,
If you do CTRL+Z, you are not killing the process. You are suspending it and sending it to the background. This probably explains why it does not work the second time you try to run it.
Try stopping the application with CTRL+C.
Mircea_D_
so i do "iwconfig wlan0 power off" to turn off the wifi power saving, and that gives me an initial ~20ms delay on ping
and after ctr+z i do ps -u root| grep python and kill the python process, and than i do fg <bg task id>
Mircea_D_
and python code
import mraa
import time
import sys
print(mraa.getPlatformType())
print(mraa.getPlatformName())
#mraa.setLogLevel(7)
class Counter:
  count = 0
c = Counter()
# inside a python interupt you cannot use 'basic' types so you'll need to use
# objects
def test(args):
  print("wooo")
  c.count+=1
for j in range(1,100):
    for pin in range(7,11):
        try:
            x = mraa.Gpio(pin)
            print('working on pin %d' % (pin, ))
            x.dir(mraa.DIR_OUT)
            for i in range(1,2):
                x.write(1)
                time.sleep(0.05)
                x.write(0)
                time.sleep(0.05)
        except:
            print('BAD pin %d' % (pin, ))
sys.exit()
#x.isr(mraa.EDGE_BOTH, test, test)
#time.sleep(5
