Software Archive
Read-only legacy content
17060 Discussions
Emotion analysis with another image resolution
Nelson_B_
I'm trying to run the Emotion analysis with another resolution different from the default 640x480, but if I try to change it the program gets stuck on the Init() method.
PXCSenseManager *sm = g_session->CreateSenseManager();
if(!sm){
	std::cout << "Failed to create SenseManager" << std::endl;
	return 1;
sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, 1920, 1080);
sm->EnableEmotion();
Handler handler(0);
if(sm->Init(&handler) >= PXC_STATUS_NO_ERROR) {
	int numFaces = 0;
	while(!g_stop){
		if(sm->AcquireFrame(true) < PXC_STATUS_NO_ERROR)
			break;
		PXCEmotion *emotionDet = sm->QueryEmotion();
		if(emotionDet != NULL) {
			PXCEmotion::EmotionData arrData[10];
			const PXCCapture::Sample *sample = sm->QueryEmotionSample();
			if(sample)
				convert_image(sample->color);
		cv::imshow("Camera Feed", g_mat_image);
		sm->ReleaseFrame();
		char c = cv::waitKey(31);
		if(c == 27) {
			g_stop = true;
This something wrong with my code?
If it isn't possible to run the emotion algorithm with a different resolution is there a way to get the feed from, for exemple, opencv crop it and send it to Intel Real Sense SDK?
Thank you
Xusheng_L_Intel
Emotion analysis ONLY supports 640x480 resolution.
