Software Archive
Read-only legacy content
17060 Discussions
Error 10310 Evaluation License Error (XE 2015)
Karl_E_
I'm trying to compile to 64bit on an evaluation copy of Parallel Studio XE 2015 - (Fortran 77) apparently you can supply me with a license key that should fix the #10310 error
Do you need my email or can you get it from my registration details?
Hubert_H_Intel
Karl,
I don't see any eval registrations under your name and email. Please let me know your email address under which your registered (or tried to register) an evaluation license of Intel® Parallel Studio XE 2015. PLEASE answer via 'Send Author A Message'.
Regards, Hubert.
Hubert_H_Intel
Karl,
Another quick option to get 64-bit enabled is to invoke the compiler with admin rights once:
Start menu -> Intel Parallel Studio XE 2015 > Compiler and Performance Libraries > Command Prompt with Intel Compiler XE.... > Intel 64 Visual Studio xxxx mode > (right-click) 'Run as Administrator' and invoke ifort without parameters.
Regards, Hubert.
