Software Archive
Read-only legacy content
17060 Discussions
Error: A build error occurred. Check the build log
Altenir_G_
https://am-xdk2.s3.amazonaws.com/cust.604f7b58-8cd6-4451-b3ff-b30690df364d/app.b4cea82a-b153-42cf-b8db-1defa91a65b4/android/guardaponto.build.201703145543.txt?X-Amz-Expires=86400&x-amz-security-token=FQoDYXdzEMD%2F%2F%2F%2F%2F%2F%2F%2F%2F%2FwEaDGQtBLScg1uCsafTxiKcA49RF4FQB9WBaL13VPf55SPhp%2FjbWjcXthB7JuvdH3I%2Fz7RS4RRT8I70IqAdxWwBrD6%2BvvV%2BFZpf2W...
Calling plugman.fetch on plugin ".../cachedPlugins.mYjeCv.tmp/cache.xsk1O_.pl/cordova-plugin-statusbar"
Copying plugin ".../cachedPlugins.mYjeCv.tmp/cache.xsk1O_.pl/cordova-plugin-statusbar" => ".../cordova_project/plugins/cordova-plugin-statusbar"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-statusbar" for platform "android
Installing "cordova-plugin-statusbar" for android
Running command: .../cordova_project/platforms/android/cordova/version
Command finished with error code 0: .../cordova_project/platforms/android/cordova/version
Install start for "cordova-plugin-statusbar" on android.
Install complete for cordova-plugin-statusbar on android.
Checking for any plugins added to the project that have not been installed in android platform
No differences found between plugins added to project and installed in android platform. Continuing...
Generating config.xml from defaults for platform "android"
Wrote out Android application name to "Guarda Ponto"
Wrote out Android package name to "br.com.altenirgama.guardaponto"
This app does not have launcher icons defined
updated project successfully
Calling plugman.fetch on plugin ".../cachedPlugins.mYjeCv.tmp/cache.STxU4M.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.mYjeCv.tmp/cache.STxU4M.pl/cordova-plugin-device" => ".../cordova_project/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-device" for platform "android
Installing "cordova-plugin-device" for android
Install start for "cordova-plugin-device" on android.
Install complete for cordova-plugin-device on android.
Calling plugman.fetch on plugin ".../cachedPlugins.mYjeCv.tmp/cache.kr5t5c.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.mYjeCv.tmp/cache.kr5t5c.pl/cordova-plugin-splashscreen" => ".../cordova_project/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-splashscreen" for platform "android
Installing "cordova-plugin-splashscreen" for android
Install start for "cordova-plugin-splashscreen" on android.
Install complete for cordova-plugin-splashscreen on android.
Calling plugman.fetch on plugin ".../cachedPlugins.mYjeCv.tmp/cache.rJbOdw.pl/cordova-plugin-compat"
Copying plugin ".../cachedPlugins.mYjeCv.tmp/cache.rJbOdw.pl/cordova-plugin-compat" => ".../cordova_project/plugins/cordova-plugin-compat"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-compat" for platform "android
Installing "cordova-plugin-compat" for android
Install start for "cordova-plugin-compat" on android.
Install complete for cordova-plugin-compat on android.
Calling plugman.fetch on plugin ".../cachedPlugins.mYjeCv.tmp/cache.QvRgoN.pl/cordova-plugin-camera"
Copying plugin ".../cachedPlugins.mYjeCv.tmp/cache.QvRgoN.pl/cordova-plugin-camera" => ".../cordova_project/plugins/cordova-plugin-camera"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-camera" for platform "android
Installing "cordova-plugin-camera" for android
Dependencies detected, iterating through them...
Plugin dependency "cordova-plugin-compat" already fetched, using that version.
Dependent plugin "cordova-plugin-compat" already installed on android.
Install start for "cordova-plugin-camera" on android.
Install complete for cordova-plugin-camera on android.
Calling plugman.fetch on plugin ".../cachedPlugins.mYjeCv.tmp/cache.bnuUbf.pl/cordova-plugin-whitelist"
Copying plugin ".../cachedPlugins.mYjeCv.tmp/cache.bnuUbf.pl/cordova-plugin-whitelist" => ".../cordova_project/plugins/cordova-plugin-whitelist"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-whitelist" for platform "android
Installing "cordova-plugin-whitelist" for android
Install start for "cordova-plugin-whitelist" on android.
Install complete for cordova-plugin-whitelist on android.
               This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
Checking config.xml for saved platforms that haven't been added to the project
Checking config.xml for saved plugins that haven't been added to the project
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../cordova_project]
Will process and update the following config files:
    Config.xml = [.../cordova_project/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [Guarda Ponto]
Updating full app name to [Guarda Ponto]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [21]
Processing preference android-installLocation [auto]
Processing preference permissions
Updating the versionCode
Updating the versionName
Processing debuggable
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../cordova_project/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
ANDROID_HOME=.../android-sdk/
JAVA_HOME=/usr/lib/jvm/java-8-oracle-amd64
Downloading file://.../cordova/gradle/gradle-2.2.1-all.zip
Unzipping /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/3d6ng971birsf8vhjv1s2o93eu/gradle-2.2.1-all.zip to /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/3d6ng971birsf8vhjv1s2o93eu
Set executable permissions for: /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/3d6ng971birsf8vhjv1s2o93eu/gradle-2.2.1/bin/gradle
Starting Build
Compiling settings file '.../cordova_project/platforms/android/settings.gradle' using StatementExtractingScriptTransformer.
Compiling settings file '.../cordova_project/platforms/android/settings.gradle' using BuildScriptTransformer.
Settings evaluated using settings file '.../cordova_project/platforms/android/settings.gradle'.
Projects loaded. Root project using build file '.../cordova_project/platforms/android/build.gradle'.
Included projects: [root project 'android', project ':CordovaLib']
Evaluating root project 'android' using build file '.../cordova_project/platforms/android/build.gradle'.
Compiling build file '.../cordova_project/platforms/android/build.gradle' using StatementExtractingScriptTransformer.
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle/1.5.0/gradle-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle-core/1.5.0/gradle-core-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder/1.5.0/builder-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint/24.5.0/lint-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/transform-api/1.5.0/transform-api-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/databinding/compilerCommon/1.0-rc5/compilerCommon-1.0-rc5.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-gradle/5.2.1/proguard-gradle-5.2.1.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-parent/5.2.1/proguard-parent-5.2.1.pom
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.core/0.7.4.201502262128/org.jacoco.core-0.7.4.201502262128.pom
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.build/0.7.4.201502262128/org.jacoco.build-0.7.4.201502262128.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-model/1.5.0/builder-model-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-test-api/1.5.0/builder-test-api-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/sdklib/24.5.0/sdklib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/sdk-common/24.5.0/sdk-common-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/common/24.5.0/common-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/manifest-merger/24.5.0/manifest-merger-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/ddms/ddmlib/24.5.0/ddmlib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/jack/jack-api/0.9.0/jack-api-0.9.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/jill/jill-api/0.9.0/jill-api-0.9.0.pom
Download https://repo1.maven.org/maven2/com/squareup/javawriter/2.5.0/javawriter-2.5.0.pom
Download https://repo1.maven.org/maven2/org/sonatype/oss/oss-parent/7/oss-parent-7.pom
Download https://repo1.maven.org/maven2/org/bouncycastle/bcpkix-jdk15on/1.48/bcpkix-jdk15on-1.48.pom
Download https://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15on/1.48/bcprov-jdk15on-1.48.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm/5.0.3/asm-5.0.3.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-parent/5.0.3/asm-parent-5.0.3.pom
Download https://repo1.maven.org/maven2/org/ow2/ow2/1.3/ow2-1.3.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-tree/5.0.3/asm-tree-5.0.3.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr-runtime/3.5.2/antlr-runtime-3.5.2.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr-master/3.5.2/antlr-master-3.5.2.pom
Download https://repo1.maven.org/maven2/org/sonatype/oss/oss-parent/9/oss-parent-9.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr/3.5.2/antlr-3.5.2.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-checks/24.5.0/lint-checks-24.5.0.pom
Download https://repo1.maven.org/maven2/org/eclipse/jdt/core/compiler/ecj/4.4.2/ecj-4.4.2.pom
Download https://repo1.maven.org/maven2/com/android/tools/annotations/24.5.0/annotations-24.5.0.pom
Download https://repo1.maven.org/maven2/com/google/guava/guava/17.0/guava-17.0.pom
Download https://repo1.maven.org/maven2/com/google/guava/guava-parent/17.0/guava-parent-17.0.pom
Download https://repo1.maven.org/maven2/com/android/databinding/baseLibrary/1.0-rc5/baseLibrary-1.0-rc5.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/33/commons-parent-33.pom
Download https://repo1.maven.org/maven2/org/apache/apache/13/apache-13.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4/4.5/antlr4-4.5.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-master/4.5/antlr4-master-4.5.pom
Download https://repo1.maven.org/maven2/commons-io/commons-io/2.4/commons-io-2.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/25/commons-parent-25.pom
Download https://repo1.maven.org/maven2/org/apache/apache/9/apache-9.pom
Download https://repo1.maven.org/maven2/com/googlecode/juniversalchardet/juniversalchardet/1.0.3/juniversalchardet-1.0.3.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-base/5.2.1/proguard-base-5.2.1.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-debug-all/5.0.1/asm-debug-all-5.0.1.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-parent/5.0.1/asm-parent-5.0.1.pom
Download https://repo1.maven.org/maven2/com/android/tools/layoutlib/layoutlib-api/24.5.0/layoutlib-api-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/dvlib/24.5.0/dvlib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/google/code/gson/gson/2.2.4/gson-2.2.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpclient/4.1.1/httpclient-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-client/4.1.1/httpcomponents-client-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/project/4.1.1/project-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpmime/4.1/httpmime-4.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-client/4.1/httpcomponents-client-4.1.pom
Download https://repo1.maven.org/maven2/net/sf/kxml/kxml2/2.3.0/kxml2-2.3.0.pom
Download https://repo1.maven.org/maven2/org/antlr/ST4/4.0.8/ST4-4.0.8.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-api/24.5.0/lint-api-24.5.0.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-analysis/5.0.3/asm-analysis-5.0.3.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-runtime/4.5/antlr4-runtime-4.5.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-annotations/4.5/antlr4-annotations-4.5.pom
Download https://repo1.maven.org/maven2/com/intellij/annotations/12.0/annotations-12.0.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcore/4.1/httpcore-4.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-core/4.1/httpcomponents-core-4.1.pom
Download https://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/5/commons-parent-5.pom
Download https://repo1.maven.org/maven2/org/apache/apache/4/apache-4.pom
Download https://repo1.maven.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/11/commons-parent-11.pom
Download https://repo1.maven.org/maven2/com/android/tools/external/lombok/lombok-ast/0.2.3/lombok-ast-0.2.3.pom
Download https://repo1.maven.org/maven2/org/abego/treelayout/org.abego.treelayout.core/1.0.1/org.abego.treelayout.core-1.0.1.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle/1.5.0/gradle-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle-core/1.5.0/gradle-core-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder/1.5.0/builder-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint/24.5.0/lint-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/transform-api/1.5.0/transform-api-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/databinding/compilerCommon/1.0-rc5/compilerCommon-1.0-rc5.jar
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-gradle/5.2.1/proguard-gradle-5.2.1.jar
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.core/0.7.4.201502262128/org.jacoco.core-0.7.4.201502262128.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-model/1.5.0/builder-model-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-test-api/1.5.0/builder-test-api-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/sdklib/24.5.0/sdklib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/sdk-common/24.5.0/sdk-common-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/common/24.5.0/common-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/manifest-merger/24.5.0/manifest-merger-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/ddms/ddmlib/24.5.0/ddmlib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/jack/jack-api/0.9.0/jack-api-0.9.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/jill/jill-api/0.9.0/jill-api-0.9.0.jar
Download https://repo1.maven.org/maven2/com/squareup/javawriter/2.5.0/javawriter-2.5.0.jar
Download https://repo1.maven.org/maven2/org/bouncycastle/bcpkix-jdk15on/1.48/bcpkix-jdk15on-1.48.jar
Download https://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15on/1.48/bcprov-jdk15on-1.48.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm/5.0.3/asm-5.0.3.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-tree/5.0.3/asm-tree-5.0.3.jar
Download https://repo1.maven.org/maven2/org/antlr/antlr-runtime/3.5.2/antlr-runtime-3.5.2.jar
Download https://repo1.maven.org/maven2/org/antlr/antlr/3.5.2/antlr-3.5.2.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-checks/24.5.0/lint-checks-24.5.0.jar
Download https://repo1.maven.org/maven2/org/eclipse/jdt/core/compiler/ecj/4.4.2/ecj-4.4.2.jar
Download https://repo1.maven.org/maven2/com/android/tools/annotations/24.5.0/annotations-24.5.0.jar
Download https://repo1.maven.org/maven2/com/google/guava/guava/17.0/guava-17.0.jar
Download https://repo1.maven.org/maven2/com/android/databinding/baseLibrary/1.0-rc5/baseLibrary-1.0-rc5.jar
Download https://repo1.maven.org/maven2/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4/4.5/antlr4-4.5.jar
Download https://repo1.maven.org/maven2/commons-io/commons-io/2.4/commons-io-2.4.jar
Download https://repo1.maven.org/maven2/com/googlecode/juniversalchardet/juniversalchardet/1.0.3/juniversalchardet-1.0.3.jar
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-base/5.2.1/proguard-base-5.2.1.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-debug-all/5.0.1/asm-debug-all-5.0.1.jar
Download https://repo1.maven.org/maven2/com/android/tools/layoutlib/layoutlib-api/24.5.0/layoutlib-api-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/dvlib/24.5.0/dvlib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar
Download https://repo1.maven.org/maven2/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpclient/4.1.1/httpclient-4.1.1.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpmime/4.1/httpmime-4.1.jar
Download https://repo1.maven.org/maven2/net/sf/kxml/kxml2/2.3.0/kxml2-2.3.0.jar
Download https://repo1.maven.org/maven2/org/antlr/ST4/4.0.8/ST4-4.0.8.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-api/24.5.0/lint-api-24.5.0.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-analysis/5.0.3/asm-analysis-5.0.3.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-runtime/4.5/antlr4-runtime-4.5.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-annotations/4.5/antlr4-annotations-4.5.jar
Download https://repo1.maven.org/maven2/com/intellij/annotations/12.0/annotations-12.0.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcore/4.1/httpcore-4.1.jar
Download https://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.jar
Download https://repo1.maven.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.jar
Download https://repo1.maven.org/maven2/com/android/tools/external/lombok/lombok-ast/0.2.3/lombok-ast-0.2.3.jar
Download https://repo1.maven.org/maven2/org/abego/treelayout/org.abego.treelayout.core/1.0.1/org.abego.treelayout.core-1.0.1.jar
Compiling build file '.../cordova_project/platforms/android/build.gradle' using BuildScriptTransformer.
Creating configuration compile
Creating configuration apk
Creating configuration provided
Creating configuration wearApp
Creating configuration androidTestCompile
Creating configuration androidTestApk
Creating configuration androidTestProvided
Creating configuration androidTestWearApp
Creating configuration testCompile
Creating configuration testApk
Creating configuration testProvided
Creating configuration testWearApp
Creating configuration debugCompile
Creating configuration debugApk
Creating configuration debugProvided
Creating configuration debugWearApp
Creating configuration testDebugCompile
Creating configuration testDebugApk
Creating configuration testDebugProvided
Creating configuration testDebugWearApp
Creating configuration releaseCompile
Creating configuration releaseApk
Creating configuration releaseProvided
Creating configuration releaseWearApp
Creating configuration testReleaseCompile
Creating configuration testReleaseApk
Creating configuration testReleaseProvided
Creating configuration testReleaseWearApp
Compiling script '.../cordova_project/platforms/android/CordovaLib/cordova.gradle' using StatementExtractingScriptTransformer.
Compiling script '.../cordova_project/platforms/android/CordovaLib/cordova.gradle' using BuildScriptTransformer.
Evaluating project ':CordovaLib' using build file '.../cordova_project/platforms/android/CordovaLib/build.gradle'.
Compiling build file '.../cordova_project/platforms/android/CordovaLib/build.gradle' using StatementExtractingScriptTransformer.
Compiling build file '.../cordova_project/platforms/android/CordovaLib/build.gradle' using BuildScriptTransformer.
Creating configuration publish
Creating configuration androidTestPublish
Creating configuration testPublish
Creating configuration debugPublish
Creating configuration testDebugPublish
Creating configuration releasePublish
Creating configuration testReleasePublish
All projects evaluated.
Selected primary task 'cdvBuildRelease' from project :
Tasks to be executed: [task ':preBuild', task ':preReleaseBuild', task ':checkReleaseManifest', task ':CordovaLib:preBuild', task ':CordovaLib:preReleaseBuild', task ':CordovaLib:compileReleaseNdk', task ':CordovaLib:compileLint', task ':CordovaLib:copyReleaseLint', task ':CordovaLib:mergeReleaseProguardFiles', task ':CordovaLib:packageReleaseRenderscript', task ':CordovaLib:checkReleaseManifest', task ':CordovaLib:prepareReleaseDependencies', task ':CordovaLib:compileReleaseRenderscript', task ':CordovaLib:generateReleaseResValues', task ':CordovaLib:generateReleaseResources', task ':CordovaLib:packageReleaseResources', task ':CordovaLib:compileReleaseAidl', task ':CordovaLib:generateReleaseBuildConfig', task ':CordovaLib:generateReleaseAssets', task ':CordovaLib:mergeReleaseAssets', task ':CordovaLib:processReleaseManifest', task ':CordovaLib:processReleaseResources', task ':CordovaLib:generateReleaseSources', task ':CordovaLib:compileReleaseJavaWithJavac', task ':CordovaLib:processReleaseJavaRes', task ':CordovaLib:transformResourcesWithMergeJavaResForRelease', task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease', task ':CordovaLib:mergeReleaseJniLibFolders', task ':CordovaLib:transformNative_libsWithMergeJniLibsForRelease', task ':CordovaLib:transformNative_libsWithSyncJniLibsForRelease', task ':CordovaLib:bundleRelease', task ':prepareAndroidCordovaLibUnspecifiedReleaseLibrary', task ':prepareReleaseDependencies', task ':compileReleaseAidl', task ':compileReleaseRenderscript', task ':generateReleaseBuildConfig', task ':generateReleaseAssets', task ':mergeReleaseAssets', task ':generateReleaseResValues', task ':generateReleaseResources', task ':mergeReleaseResources', task ':processReleaseManifest', task ':processReleaseResources', task ':generateReleaseSources', task ':compileReleaseJavaWithJavac', task ':compileReleaseNdk', task ':compileReleaseSources', task ':transformClassesWithDexForRelease', task ':mergeReleaseJniLibFolders', task ':transformNative_libsWithMergeJniLibsForRelease', task ':processReleaseJavaRes', task ':transformResourcesWithMergeJavaResForRelease', task ':packageRelease', task ':assembleRelease', task ':cdvBuildRelease']
:preBuild (Thread[main,5,main]) started.
:preBuild
Skipping task ':preBuild' as it has no actions.
:preBuild UP-TO-DATE
:preBuild (Thread[main,5,main]) completed. Took 0.017 secs.
:preReleaseBuild (Thread[main,5,main]) started.
:preReleaseBuild
Skipping task ':preReleaseBuild' as it has no actions.
:preReleaseBuild UP-TO-DATE
:preReleaseBuild (Thread[main,5,main]) completed. Took 0.001 secs.
:checkReleaseManifest (Thread[main,5,main]) started.
Executing task ':checkReleaseManifest' (up-to-date check took 0.0 secs) due to:
  Task has not declared any outputs.
:checkReleaseManifest (Thread[main,5,main]) completed. Took 0.002 secs.
:CordovaLib:preBuild (Thread[main,5,main]) started.
Skipping task ':CordovaLib:preBuild' as it has no actions.
:CordovaLib:preBuild UP-TO-DATE
:CordovaLib:preBuild (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:preReleaseBuild (Thread[main,5,main]) started.
Skipping task ':CordovaLib:preReleaseBuild' as it has no actions.
:CordovaLib:preReleaseBuild UP-TO-DATE
:CordovaLib:preReleaseBuild (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:compileReleaseNdk (Thread[main,5,main]) started.
Skipping task ':CordovaLib:compileReleaseNdk' as it has no source files.
:CordovaLib:compileReleaseNdk UP-TO-DATE
:CordovaLib:compileReleaseNdk (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:compileLint (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileLint' (up-to-date check took 0.0 secs) due to:
:CordovaLib:compileLint (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:copyReleaseLint (Thread[main,5,main]) started.
Skipping task ':CordovaLib:copyReleaseLint' as it has no source files.
:CordovaLib:copyReleaseLint UP-TO-DATE
:CordovaLib:copyReleaseLint (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:mergeReleaseProguardFiles (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeReleaseProguardFiles' (up-to-date check took 0.009 secs) due to:
  No history is available.
:CordovaLib:mergeReleaseProguardFiles (Thread[main,5,main]) completed. Took 0.016 secs.
:CordovaLib:packageReleaseRenderscript (Thread[main,5,main]) started.
Skipping task ':CordovaLib:packageReleaseRenderscript' as it has no source files.
:CordovaLib:packageReleaseRenderscript UP-TO-DATE
:CordovaLib:packageReleaseRenderscript (Thread[main,5,main]) completed. Took 0.002 secs.
:CordovaLib:checkReleaseManifest (Thread[main,5,main]) started.
Executing task ':CordovaLib:checkReleaseManifest' (up-to-date check took 0.0 secs) due to:
:CordovaLib:checkReleaseManifest (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:prepareReleaseDependencies (Thread[main,5,main]) started.
Executing task ':CordovaLib:prepareReleaseDependencies' (up-to-date check took 0.0 secs) due to:
:CordovaLib:prepareReleaseDependencies (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:compileReleaseRenderscript (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileReleaseRenderscript' (up-to-date check took 0.008 secs) due to:
:CordovaLib:compileReleaseRenderscript (Thread[main,5,main]) completed. Took 0.037 secs.
:CordovaLib:generateReleaseResValues (Thread[main,5,main]) started.
Executing task ':CordovaLib:generateReleaseResValues' (up-to-date check took 0.001 secs) due to:
:CordovaLib:generateReleaseResValues (Thread[main,5,main]) completed. Took 0.01 secs.
:CordovaLib:generateReleaseResources (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateReleaseResources' as it has no actions.
:CordovaLib:generateReleaseResources (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:packageReleaseResources (Thread[main,5,main]) started.
Executing task ':CordovaLib:packageReleaseResources' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:packageReleaseResources'.
Unable do incremental execution: full task run
QueuedCruncher is using .../android-sdk/build-tools/25.0.0/aapt
:CordovaLib:packageReleaseResources (Thread[main,5,main]) completed. Took 0.027 secs.
:CordovaLib:compileReleaseAidl (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileReleaseAidl' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:compileReleaseAidl'.
:CordovaLib:compileReleaseAidl (Thread[main,5,main]) completed. Took 0.007 secs.
:CordovaLib:generateReleaseBuildConfig (Thread[main,5,main]) started.
Executing task ':CordovaLib:generateReleaseBuildConfig' (up-to-date check took 0.005 secs) due to:
:CordovaLib:generateReleaseBuildConfig (Thread[main,5,main]) completed. Took 0.03 secs.
:CordovaLib:generateReleaseAssets (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateReleaseAssets' as it has no actions.
:CordovaLib:generateReleaseAssets UP-TO-DATE
:CordovaLib:generateReleaseAssets (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:mergeReleaseAssets (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeReleaseAssets' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:mergeReleaseAssets'.
:CordovaLib:mergeReleaseAssets (Thread[main,5,main]) completed. Took 0.013 secs.
:CordovaLib:processReleaseManifest (Thread[main,5,main]) started.
Executing task ':CordovaLib:processReleaseManifest' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:processReleaseManifest'.
Merging main manifest .../cordova_project/platforms/android/CordovaLib/AndroidManifest.xml
Merging result:SUCCESS
Merged manifest saved to .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/AndroidManifest.xml
:CordovaLib:processReleaseManifest (Thread[main,5,main]) completed. Took 0.054 secs.
:CordovaLib:processReleaseResources (Thread[main,5,main]) started.
Executing task ':CordovaLib:processReleaseResources' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:processReleaseResources'.
Starting process 'command '.../android-sdk/build-tools/25.0.0/aapt''. Working directory: .../cordova_project/platforms/android/CordovaLib Command: .../android-sdk/build-tools/25.0.0/aapt package -f --no-crunch -I .../android-sdk/platforms/android-23/android.jar -M .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/aapt/AndroidManifest.xml -S .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/res -A .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/assets -m -J .../cordova_project/platforms/android/CordovaLib/build/generated/source/r/release --custom-package org.apache.cordova --non-constant-id -0 apk --output-text-symbols .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release
Successfully started process 'command '.../android-sdk/build-tools/25.0.0/aapt''
:CordovaLib:processReleaseResources (Thread[main,5,main]) completed. Took 0.372 secs.
:CordovaLib:generateReleaseSources (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateReleaseSources' as it has no actions.
:CordovaLib:generateReleaseSources (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:compileReleaseJavaWithJavac (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileReleaseJavaWithJavac' (up-to-date check took 0.005 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:compileReleaseJavaWithJavac'.
Compiling with JDK Java compiler API.
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
:CordovaLib:compileReleaseJavaWithJavac (Thread[main,5,main]) completed. Took 1.657 secs.
:CordovaLib:processReleaseJavaRes (Thread[main,5,main]) started.
Skipping task ':CordovaLib:processReleaseJavaRes' as it has no source files.
:CordovaLib:processReleaseJavaRes UP-TO-DATE
:CordovaLib:processReleaseJavaRes (Thread[main,5,main]) completed. Took 0.002 secs.
:CordovaLib:transformResourcesWithMergeJavaResForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformResourcesWithMergeJavaResForRelease' (up-to-date check took 0.0 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformResourcesWithMergeJavaResForRelease'.
:CordovaLib:transformResourcesWithMergeJavaResForRelease (Thread[main,5,main]) completed. Took 0.009 secs.
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease' (up-to-date check took 0.016 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease'.
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease (Thread[main,5,main]) completed. Took 0.05 secs.
:CordovaLib:mergeReleaseJniLibFolders (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeReleaseJniLibFolders' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:mergeReleaseJniLibFolders'.
:CordovaLib:mergeReleaseJniLibFolders (Thread[main,5,main]) completed. Took 0.005 secs.
:CordovaLib:transformNative_libsWithMergeJniLibsForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformNative_libsWithMergeJniLibsForRelease' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformNative_libsWithMergeJniLibsForRelease'.
:CordovaLib:transformNative_libsWithMergeJniLibsForRelease (Thread[main,5,main]) completed. Took 0.003 secs.
:CordovaLib:transformNative_libsWithSyncJniLibsForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformNative_libsWithSyncJniLibsForRelease' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformNative_libsWithSyncJniLibsForRelease'.
:CordovaLib:transformNative_libsWithSyncJniLibsForRelease (Thread[main,5,main]) completed. Took 0.002 secs.
:CordovaLib:bundleRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:bundleRelease' (up-to-date check took 0.001 secs) due to:
:CordovaLib:bundleRelease (Thread[main,5,main]) completed. Took 0.035 secs.
:prepareAndroidCordovaLibUnspecifiedReleaseLibrary (Thread[main,5,main]) started.
Executing task ':prepareAndroidCordovaLibUnspecifiedReleaseLibrary' (up-to-date check took 0.0 secs) due to:
:prepareAndroidCordovaLibUnspecifiedReleaseLibrary (Thread[main,5,main]) completed. Took 0.032 secs.
Executing task ':prepareReleaseDependencies' (up-to-date check took 0.0 secs) due to:
:prepareReleaseDependencies (Thread[main,5,main]) completed. Took 0.001 secs.
:compileReleaseAidl
Executing task ':compileReleaseAidl' (up-to-date check took 0.002 secs) due to:
All input files are considered out-of-date for incremental task ':compileReleaseAidl'.
:compileReleaseAidl (Thread[main,5,main]) completed. Took 0.004 secs.
Executing task ':compileReleaseRenderscript' (up-to-date check took 0.002 secs) due to:
:compileReleaseRenderscript (Thread[main,5,main]) completed. Took 0.008 secs.
Executing task ':generateReleaseBuildConfig' (up-to-date check took 0.001 secs) due to:
:generateReleaseBuildConfig (Thread[main,5,main]) completed. Took 0.005 secs.
Skipping task ':generateReleaseAssets' as it has no actions.
:generateReleaseAssets (Thread[main,5,main]) completed. Took 0.001 secs.
:mergeReleaseAssets
Executing task ':mergeReleaseAssets' (up-to-date check took 0.264 secs) due to:
All input files are considered out-of-date for incremental task ':mergeReleaseAssets'.
:mergeReleaseAssets (Thread[main,5,main]) completed. Took 0.62 secs.
Executing task ':generateReleaseResValues' (up-to-date check took 0.0 secs) due to:
:generateReleaseResValues (Thread[main,5,main]) completed. Took 0.003 secs.
Skipping task ':generateReleaseResources' as it has no actions.
:mergeReleaseResources (Thread[main,5,main]) started.
Executing task ':mergeReleaseResources' (up-to-date check took 0.011 secs) due to:
All input files are considered out-of-date for incremental task ':mergeReleaseResources'.
:mergeReleaseResources (Thread[main,5,main]) completed. Took 6.722 secs.
Executing task ':processReleaseManifest' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':processReleaseManifest'.
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/android/CordovaLib/unspecified/release/AndroidManifest.xml
Merging main manifest .../cordova_project/platforms/android/AndroidManifest.xml
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/android/CordovaLib/unspecified/release/AndroidManifest.xml
Merging manifest with lower [android:CordovaLib:unspecified:release] AndroidManifest.xml:20:1-27:12
Merging uses-sdk with lower [android:CordovaLib:unspecified:release] AndroidManifest.xml:25:5-44
Merged manifest saved to .../cordova_project/platforms/android/build/intermediates/manifests/full/release/AndroidManifest.xml
:processReleaseManifest (Thread[main,5,main]) completed. Took 0.026 secs.
Executing task ':processReleaseResources' (up-to-date check took 0.036 secs) due to:
All input files are considered out-of-date for incremental task ':processReleaseResources'.
Starting process 'command '.../android-sdk/build-tools/25.0.0/aapt''. Working directory: .../cordova_project/platforms/android Command: .../android-sdk/build-tools/25.0.0/aapt package -f --no-crunch -I .../android-sdk/platforms/android-23/android.jar -M .../cordova_project/platforms/android/build/intermediates/manifests/full/release/AndroidManifest.xml -S .../cordova_project/platforms/android/build/intermediates/res/merged/release -A .../cordova_project/platforms/android/build/intermediates/assets/release -m -J .../cordova_project/platforms/android/build/generated/source/r/release -F .../cordova_project/platforms/android/build/intermediates/res/resources-release.ap_ --custom-package br.com.altenirgama.guardaponto -0 apk --output-text-symbols .../cordova_project/platforms/android/build/intermediates/symbols/release
Unknown source file : .../cordova_project/platforms/android/build/intermediates/assets/release/www/bower_components/Materialize: error: Directory is case-insensitive equivalent to: .../cordova_project/platforms/android/build/intermediates/assets/release/www/bower_components/materialize
:processReleaseResources FAILED
:processReleaseResources (Thread[main,5,main]) completed. Took 0.068 secs.
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':processReleaseResources'.
> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '.../android-sdk/build-tools/25.0.0/aapt'' finished with non-zero exit value 1
* Try:
Run with --stacktrace option to get the stack trace. Run with --debug option to get more log output.
BUILD FAILED
Total time: 25.145 secs
Stopped 0 compiler daemon(s).
Error: Error code 1 for command: .../cordova_project/platforms/android/gradlew with args: cdvBuildRelease,-b,.../cordova_project/platforms/android/build.gradle,--no-daemon,-Pandroid.useDeprecatedNdk=true,--info
Shahab_L_Intel
Hi Altenir,
This seems to be the relevant part:
It looks like you have a 'materialize' and a 'Materialize' folder. Rename one of them to avoid the problem.
Altenir_G_
Solved
Thank you
