Software Archive
Read-only legacy content
17060 Discussions
Error: Could not retrieve plugin "https://github.com/cranberrygame/cordova-plugin-game --variable APP_ID='YOUR_GOOGLE_PLAY_GAME_
James_F_2
  • Error: Could not retrieve plugin "https://github.com/cranberrygame/cordova-plugin-game --variable APP_ID='YOUR_GOOGLE_PLAY_GAME_APP_ID'".
  • Error: Could not fetch plugin "https://github.com/cranberrygame/cordova-plugin-game --variable APP_ID='YOUR_GOOGLE_PLAY_GAME_APP_ID'".
    I followed the tutorial exactly, this game needs to be out by Halloween and I've worked on it every day following the tutorial of how to export from Construct 2 to Intel XDX plus how to add plugin, according to Construct 2, to intel XDX.
  • Still says build failed.
    I followed the instructions exactly for both tutorials on how to add plugin to Intel XDX and how to go from Construct adding to Intel XDX project folder. Why are the tutorials not working? ive done them several times each time says Build Failed.
    That error message doesn't say how or where to fix the problem.
James_F_2
Got it!  I had to use the Construct 2 Use New Intel Format thing in Construct 2. then import XDX project.
I guess the tutorials are for if you dont have access to  it.  Fixed it!  All what was needed was ticking the box in Construct 2 use new intel xdx format, then renaming the XDX file with _ inbetween the words instead of spaces.
