Software Archive
Read-only legacy content
17060 Discussions
Error: Unable to upload the project files
Rafael_O_2
I can not build a project that was built in an old account.
In the new account generates error "Unable to upload the project files"
Do not upload and does not generate the APK
Rafael_O_2
The problem is fixed with the new version xdk_web_win_master_3240.exe
Pamela_H_Intel
Rafael,
I will check with the database engineer to see if combining your accounts created a build issue.
Pamela
Pamela_H_Intel
The database engineer thinks that you might need to fix your certificates in Build Settings. Try that.
<edit> Meaning select the correct cert for the project you are building.
Rafael_O_2
The certificate is the same for both accounts:
In the former he makes uploading> processing> building and generates success with APK.
In the new it does the uploading and generates the error "Unable to upload the project files"
Old Account ok
New
New Account
Hamilton_Tenório_da_
Valued Contributor I
@Rafael> I guess you have the same problem that me. I have 2 accounts (2 certificates) and it seems that accounts are merged. When I try to build, I receive this message (unable...). Then I created a new account. I am using this new one to build with the 2 old certificates. It is working OK.
Marcelo_S_
I am facing the same issue, tried the solution proposed by Hamilton but no success so far.
Rafael_O_2
Marcelo_S_
Thanks for sharing Rafael, I just updated and now I can build with no problems.
Pamela_H_Intel
This issue has been resolved. This thread is now closed.
