Software Archive
Read-only legacy content
17060 Discussions
Error code 65 when building IOS app
alibeigi__amirreza
I have created my game with Construct 2 and exported it to cordova , after that I imported it to intel xdk and I have started work to export to ios , after building I get this error :
The following build commands failed:
	CompileC build/Robo\ Copter.build/Release-iphoneos/Robo\ Copter.build/Objects-normal/armv7/AdMobPlugin.o Robo\ Copter/Plugins/cordova-plugin-ad-admob/AdMobPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
(1 failure)
Error: Error code 65 for command: xcodebuild with args: -xcconfig,.../builds/build.2016-11-28.09-05-02.D5Cxki.tmp/cordova_project/platforms/ios/cordova/build-release.xcconfig,-project,Robo Copter.xcodeproj,ARCHS=armv7 arm64,-target,Robo Copter,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../builds/build.2016-11-28.09-05-02.D5Cxki.tmp/cordova_project/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../builds/build.2016-11-28.09-05-02.D5Cxki.tmp/cordova_project/platforms/ios/build/sharedpch
PaulF_IntelCorp
Please post the entire detailed build log as a TXT file attachment (use the "Attach Files to Post" link below the edit window). The real error is likely above the part that you posted, in the detailed build log.
alibeigi__amirreza
I have attached my build txt
PaulF_IntelCorp
Here's the source of the problem, per the detailed build log:
In file included from .../builds/build.2016-11-29.08-40-59.MNZY2o.tmp/cordova_project/platforms/ios/RoboCopter/Plugins/cordova-plugin-ad-admob/AdMobPlugin.m:5:
.../builds/build.2016-11-29.08-40-59.MNZY2o.tmp/cordova_project/platforms/ios/RoboCopter/Plugins/cordova-plugin-ad-admob/AdMobPlugin.h:9:9: fatal error: 'GoogleMobileAds/GADAdSize.h' file not found
#import <GoogleMobileAds/GADAdSize.h>
1 error generated.
Something wrong with the "cordova-plugin-ad-admob" plugin. Might be caused by some conflicts between plugins or ??? Try removing it and you should see the build succeed. Not able to tell you why the plugin is causing a problem, that's something you'll have to take up with the plugin developer.
alibeigi__amirreza
1 error generated.
I have remover admob sdk and google-extras manually but I don't remove cordova-plugin-ad-admob and build was successful and admob is showing
John_F_7
alibeigi, amirreza wrote:
Hi there, I would like to ask, how do you remove admob sdk and google-extras manually??
PaulF_IntelCorp
Use the plugin management tool on the Projects tab. Click the "-" icon along the right edge of the plugin you want to remove. See the docs > https://software.intel.com/en-us/xdk/docs/add-manage-project-plugins < for more info.
