Software Archive
Read-only legacy content
17060 Discussions
Error compiling build for Android/crosswalk android with intel xdk2366
Ming_Chiet_C_
I am just curious about the error that I am getting. 3 days ago, I was able to compile my apk for both crosswalk and android with Intel XDK.
Now, I keep getting the error
An unexpected error occured while attempting to build the application.
I noted that I am getting the specific error in the log.
Installing "com.mcm.plugins.androidinappbilling" for android
Install start for "com.mcm.plugins.androidinappbilling" on android.
path does not exist: .../Mxxxh/platforms/android/src/com/android/vending/billing
path does not exist: .../Mxxxh/platforms/android/src/com/smartmobilesoftware/inappbilling
path does not exist: .../Mxxxh/platforms/android/src/com/smartmobilesoftware/util
Installing "org.apache.cordova.file" for android
Install start for "org.apache.cordova.file" on android.
path does not exist: .../Mxxxh/platforms/android/src/org/apache/cordova/file
Installing "org.apache.cordova.contacts" for android
Install start for "org.apache.cordova.contacts" on android.
path does not exist: .../Mxxxh/platforms/android/src/org/apache/cordova/contacts
Installing "org.apache.cordova.inappbrowser" for android
Install start for "org.apache.cordova.inappbrowser" on android.
path does not exist: .../Mxxxh/platforms/android/src/org/apache/cordova/inappbrowser
Is this an issue with the included plugins or third party plugins or some other issue e.g plugin not compatible to intel xdk 2366?
I am compiling the APK for my app made with Construct2.
regards
Damon
Elroy_A_Intel
Are you providing this plugins locally or via the default listing?
Ming_Chiet_C_
Via default listing
John_H_Intel2
I see you have completed several build successfully. Did you get the issue figured out?
Ming_Chiet_C_
For the crosswalk, I am able to compile successfully now. But for Android, although it too is successful, the apk cant be installed. Any other suggestions to check? The cordova CLI version is 4.1.2.
The change that I made to fix it was probably due to the build settings-app version code to be a single number e.g 1 or 2.
John_H_Intel2
What kind of device are you trying to install it on?
Does it install and then fail to launch or does it fail to install altogether?
How are you trying to install, OTA, adb, other?
Ming_Chiet_C_
Xiaomi Redmi 2. It failed to install altogether. I am just downloading it via the phone and installing it.
Ming_Chiet_C_
Just to add on, I noted that while I am able to run the crosswalk APK, when I checked the package name, with Package Name Viewer app, it shows as not specified. Partly because that, I believe that why I am failing/unable to upload when I submit to the amazon app store regarding the package name error
Ming_Chiet_C_
Ok. I resolved the crosswalk  no package specificied issue. Can you suggest what else to check for the Android build via Intel XDK?
