Software Archive
Read-only legacy content
17060 Discussions
Error in Running Native Compile Code on MIC
Sankalp_J_
I trying to run GAMESS code on MIC.
I successfully compile the code only for MIC but when trying to run code on mic's its run but after few second its showing below error ...
mpiexec.hydra -f /scratch/210797/new2.processes.mpd -genv I_MPI_DEBUG 5 /home/internal/bioinfo/gamess/gamess.02.x
[-1] MPI startup(): Imported environment partly inaccesible. Map=0 Info=e7900f0
[-1] MPI startup(): Imported environment partly inaccesible. Map=0 Info=d3460f0
[-1] MPI startup(): Imported environment partly inaccesible. Map=0 Info=d2550f0
[-1] MPI startup(): Imported environment partly inaccesible. Map=0 Info=d26a0f0
[0] DAPL startup(): trying to open default DAPL provider from dat registry: ofa-v2-mlx4_0-1
[1] DAPL startup(): trying to open default DAPL provider from dat registry: ofa-v2-mlx4_0-1
[2] DAPL startup(): trying to open default DAPL provider from dat registry: ofa-v2-mlx4_0-1
[3] DAPL startup(): trying to open default DAPL provider from dat registry: ofa-v2-mlx4_0-1
220-mic1:1677:c8269700: 7606 us(7606 us): ycn220-mic1.en.yuva.param:1679:65357700: 7897 us(7897 us): getlocalipaddrr
: NETDEV = eth0 but not configured on system? ERR = Unknown error -1
220-mic1.:1679:65357700: 8011 us(114 us): getlocalipaddr Unknown error -1
getlocalipaddr: NETDEV = eth0 but not configured on system? ERR = Unknown error -1
[2] DAPL startup(): trying to open default DAPL provider from dat registry: ofa-v2-mlx4_0-2
Please help me !!!
Loc_N_Intel
Where can I get the GAMESS code?  Let me know how you compile it for MIC, I try to reproduce the problem. Thanks.
