Software Archive
Read-only legacy content
17060 Discussions
Error spawning df.exe
Intel_C_Intel
I just started using a new system at work. The first time I tried to compile a program, I got the "error spawning df.exe" error. I tried the recommendation of the FAQ, using the REG USER program, but this did not solve the problem. What else can I try?
5.0, eh? Have you installed the 5.0D update?
If you do Start..Programs..Visual Fortran 5..F90 and, at the prompt, type "df -what" (no quotes), what happens?
The usual reason for this error is that Developer Studio can't find the compiler. If you look under Tools..Options..Directories, the Executable Files list should include the directory with DF.EXE (usually ..DevStudioDFBIN).
Steve
Jugoslav_Dujic
Valued Contributor II
The second usual reason for that is that your system is out of virtual memory (and 5.0 compiler is a real eater of it). If Steve's suggestion
won't work, try a) increasing paging file size on NT/2000 b) don't have many other programs opened c) buy more RAM d) buy new version (6.5)
(sorted by convenience).
Jugoslav
If you are getting "error spawning DF.EXE", the compiler isn't running yet, so that can't be an issue. I have not seen this error related to virtual memory use.
Steve
Jugoslav_Dujic
You're right Steve -- sorry -- I mixed it with 'error executing df.exe' without an additional error message.
Jugoslav
