Software Archive
Read-only legacy content
17060 Discussions
Error while building Android Crosswalk APK
Clement_C_1
Hi everyone,
I'm new to using Intel XDK so could use some help here.  I keep getting this error while building:
Error: Plugin "https://github.com/cranberrygame/cordova-plugin-game --variable APP_ID='YOUR_GOOGLE_PLAY_GAME_APP_ID'" failed to install.
Did anyone have similar issue before?
Also, how can I delete apps in development shown in the built panel?  A lot of those apps are built for testing purposes and I need to delete them to upload completed versions.
Clement
Swati_S_Intel1
You have to get your own Google Play developer account and get the game ID and stick that into XDX as described on the plugin page.
Amrita_C_Intel
Did you try to replace app id with your google play app id?
The link you provided gives documentation on how to set it up in the xdk
did you try following those steps?
How to delete apps?
If you want to delete app from XDK please see the attached screenshot.
If you would like to delete from disk please follow this link: https://software.intel.com/en-us/xdk/blog/remove-xdk-local-data
Anusha_M_Intel1
You can delete apps in development by logging in to: https://appcenter.html5tools-software.intel.com/csd/controlpanel.aspx
Clement_C_1
Hey everyone,
Thanks for the help.  I didn't replace the Google App ID that's why.  I've been doing too much too quickly so it's my bad for missing out such an important step.  As for deleting the app, thanks for pointing out where the control panel is.
Cheers,
Clement
