Software Archive
Read-only legacy content
17060 Discussions
Evaluation License
Sangkha_B_
I have installed Intel Parallel Studio XE 2015 Update 2 Composer for project work. I have used an Evaluation License for the setup of the same.
I will be receiving the License File in a few days.
Could you please suggest me if the Compiler will still run all the components without a License File till I activate the same?
If it does work, please suggest the duration till when it can be used without the License File viz; 15 or 30 days.
Hubert_H_Intel
You can install Intel® Parallel Studio XE in evaluation mode with is a 30-days period where the product runs with full functionality. You can copy over then the license file to a default license directory which overrides the eval activation. The license file is also running 30 days from the day of registrations.
If you have more questions, let me know.
Regards, Hubert
